Contact cement jelly
Forum topic by emiliof posted 05-10-2013 09:57 AM 1472 views 0 times favorited 9 replies Add to Favorites Watch
View emiliof's profile
emiliof
33 posts in 2229 days
05-10-2013 09:57 AM
Topic tags/keywords: question gluing
Hi fellows,
I rescued an old can of contact cement from my basement and when opened it what I found was a thick contact cement jelly. I know I´d not be saving a fortune, but is it any way to bring that jelly into a fluid again? What should I add to it apart from thinner?
Emilio
-- Emilio
9 replies so far
View NiteWalker's profile
NiteWalker
2738 posts in 2812 days
#1 posted 05-10-2013 12:23 PM
I’d just toss it.
You’ll spend more in solvent and time to try to get it usable again.
View helluvawreck's profile
helluvawreck
32086 posts in 3102 days
#2 posted 05-10-2013 12:32 PM
I don’t think that you can salvage it. If it were even to work I think it would leave a lumpy and/or uneven surface.
helluvawreck aka Charles
View bondogaposis's profile
bondogaposis
5149 posts in 2586 days
#3 posted 05-10-2013 12:47 PM
Chuck it!
-- Bondo Gaposis
5233 posts in 2728 days
#4 posted 05-10-2013 02:25 PM
The glue has started to cure, a process you can’t reverse. So I won’t say what’s already been said a few times…...
View MarcusM's profile
MarcusM
57 posts in 3215 days
#5 posted 05-10-2013 02:27 PM
You can get a thinner for contact cement that works reasonably well, but as NiteWalker said, it’s not worth the money or time to use it.
Mark
-- Tilbilly Mark
View Loren's profile
10477 posts in 3883 days
#6 posted 05-10-2013 03:51 PM
Read here:
http://www.knifenetwork.com/forum/showthread.php?t=53370
If it’s not too far gone it can be rescued.
It depends on the price of replacing it. A quart of Barge (the
best stuff) is about $30.
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#7 posted 05-10-2013 04:01 PM
I’d set it aside for shop projects that are less than critical, and buy a new can for your premium work.
I just used a thick and slightly lumpy bit in the bottom of an old can for a shop project and it came out fine.
-- I yam what I yam and that's all what I yam
View DS's profile
DS
3044 posts in 2655 days
#8 posted 05-10-2013 04:02 PM
Sure, you might be able to rescue this, but if you value your end product, I wouldn’t risk the failure of the adhesive when a few bucks gets a nice fresh can of reliable product.
It’s like assuming Jello will re-gel after you’ve re-liquified it.
There’s a chemical change that takes place when it gels—I can’t imagine that its going to be as good as the first time you put it in the fridge.
emiliof
#9 posted 05-11-2013 01:50 AM
Thank you all guys!
I think my best bet is not using it… at least not for important projects… I still have some contact cement in good condition anyway :-) cheers,
Emilio
-- Emilio
