Shop made Tools of Your Dreams.
« back to Hand Tools forum
Forum topic by Airframer posted 05-10-2013 01:06 AM 4463 views 0 times favorited 123 replies Add to Favorites Watch
View Airframer's profile
Airframer
3043 posts in 1860 days
05-10-2013 01:06 AM
Topic tags/keywords: resource
Like we need another “Of Your Dreams” topics around here but here goes another one.
I figured this would be a good spot to showcase or dream up your cabinet of shop made tools. Buying them is great but building something with a tool you made yourself is priceless.
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
123 replies so far
Airframer
#1 posted 05-10-2013 01:14 AM
I have started another tool project as a means of procrastinating on my bench lol. Seriously though I have been wanting to build a Layout compass for a while and have not allowed myself to start because of the workbench backlog but I think I need to clear this out of my head to allow room for the bench to sneak back in.
Based off of this design but made from wood and brass.
I was able to get the hinge done today not just need to make the rest of it..
View Mosquito's profile
Mosquito
9215 posts in 2199 days
#2 posted 05-10-2013 05:30 AM
That was such a nice saw you made there. Really like it.
It’s not done yet, but I’m workin’ on a jointer plane
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
Airframer
#3 posted 05-10-2013 05:42 AM
Well now that you have your bench finished you can get back to work on that!
View Rick_M's profile
Rick_M
11121 posts in 2287 days
#4 posted 05-10-2013 06:13 AM
I would like to have a small set of awls for starting drill bits. Larger and with steeper angles than a scratch awl. I can just use a drill bit and whack it but a set of awls would be nice, maybe 3 or 4 sizes.
-- http://thewoodknack.blogspot.com/
View OnlyJustME's profile
OnlyJustME
1562 posts in 2284 days
#5 posted 05-10-2013 01:13 PM
I think they’re called gimlets Rick.
-- In the end, when your life flashes before your eyes, will you like what you see?
View oldnovice's profile
oldnovice
6550 posts in 3275 days
#6 posted 05-10-2013 04:14 PM
OnlyJustME, I’ll have two vodka gimlet please for some out of shop down time!
I typically use a spot drill to start holes particularly in hardwoods when I can’t use a Brad point bit.
View Tim's profile
Tim
3734 posts in 1868 days
#7 posted 05-10-2013 05:27 PM
I had planned to use an old screwdriver and grind it into an awl. Is there enough decent steel in a screwdriver to make that worth it after the tip is ground off? Otherwise I think I have a junk triangular file I can cut and grind down and use. What else do you guys use as steel for awls?
Airframer
#8 posted 05-10-2013 05:31 PM
I used a taper set pin for mine. It is hardened steel and pretty cheap at ACE. It’s not as slim as I would like but it does a great job of marking drill holes.
Mosquito
#9 posted 05-10-2013 05:37 PM
The awl that I got from the marking knife swap was made from a spade bit. The marking knife was made from the spade part, and the awl was made from the other end
View Don Broussard's profile
Don Broussard
3474 posts in 2158 days
#10 posted 05-10-2013 06:04 PM
@Tim—I ground down an old Craftsman Philips screwdriver that was all buggered up into a awl. Nothing fancy, but it does mark where it’s tapped down.
EDIT—Or maybe it’s a gimlet. Not sure now.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View woodworkerforchrist's profile
woodworkerforchrist
160 posts in 1764 days
#11 posted 05-10-2013 06:21 PM
I would love to build a shop built scrollsaw and maybe even a lathe:)
-- Marty from MinneSNOWta
Mosquito
#12 posted 05-10-2013 06:38 PM
I want to make a treadle lathe some day too…
And I have this idea… I’ve got a belt driven scroll saw (old wooden one) that I’d like to use. My idea is getting a treadle sewing machine table (no sewing machine, just the treadle mechanism) and make it so I can universally mount the scroll saw, or a grinder, or a mini lathe, or anything of the sort on it to use. Would be fun
View Hammerthumb's profile
Hammerthumb
2820 posts in 1882 days
#13 posted 05-10-2013 07:46 PM
Mosquito – that sounds like too much work, but if I make something like that you will be the first person I call for foot peddle help! One man power – how does that equate to horsepower?
-- Paul, Las Vegas
Mosquito
#14 posted 05-10-2013 07:53 PM
lol I like the idea of an unplugged shop. At least to an extent. I like the options of being able to do things either way. All depends on if it’s a project I’m doing so I can have and use it, or if it’s a project I’m doing because I want to make it, and having it afterwards is just a bonus lol
Rick_M
#15 posted 05-10-2013 07:56 PM
A gimlet is for starting screw holes.
showing 1 through 15 of 123 replies
