Best Router Bit for hogging out material?
« back to Joinery forum
Forum topic by ToddJB posted 05-09-2013 08:42 PM 4355 views 0 times favorited 18 replies Add to Favorites Watch
View ToddJB's profile
ToddJB
7910 posts in 2098 days
05-09-2013 08:42 PM
I’m getting ready to build some wall benches and I’m going to be using material I have on hand. Which means 4×6’s for legs and 2×4’s for cross beams. I’d like to cut out notches out of the inside corners of the 4×6’s for the 2X4’s to rest in. So I need to hog out a bunch of wood up to 1.5” deep. What is your preferred bit for such an activity?
Links appreciated ;)
Note: Is it called a Mortise if it’s open on two sides (the top and side) or is that just a notch?
-- I came - I sawed - I over-built
18 replies so far
View crank49's profile
crank49
4030 posts in 2939 days
#1 posted 05-09-2013 10:00 PM
You mean a lap joint?
I hog those out with my circular saw, then hammer, and finally clean it up with a chisel.
http://www.thisoldhouse.com/toh/skill-builder/0,,211880,00.html
View Greg D's profile
Greg D
238 posts in 1919 days
#2 posted 05-09-2013 10:45 PM
Skillsaw & chisel, or router with a flat bottom dado bit or bowl bit. If your cutting the 4×6 to fit the 2×4 in its a lap joint. If you dap bother pieces its a half lap.
Good luck
-- Greg D, Cen. CA, "Keep it on the Level, Do it Right the First Time!"
View gfadvm's profile
gfadvm
14940 posts in 2658 days
#3 posted 05-10-2013 02:03 AM
Dado blades on a tablesaw? If I understand the joint you are after.
View NiteWalker's profile
NiteWalker
2736 posts in 2545 days
#4 posted 05-10-2013 02:12 AM
Dado set to rough out most of the material, router and any straight to finish it up.
Also, using a forstner with depth stop to hog out the waste works well too.
View bondogaposis's profile
bondogaposis
4687 posts in 2319 days
#5 posted 05-10-2013 04:04 AM
Routers are not the best tool for hogging out a lot of material as you can only take small bites w/ each pass. If you would be a little more specific info about the joint you intend to make you will get better feedback.
-- Bondo Gaposis
ToddJB
#6 posted 05-10-2013 01:21 PM
Sorry, I don’t think I was describing what I was envisioning very well. I don’t think a lap joint is what I’m looking for.
Here’s a pic (that is NOT to scale):
Would you still try to use a skillsaw or dados?
gfadvm
#7 posted 05-10-2013 01:30 PM
Skilsaw/ dados won’t help there. I’d use a forstner or spade bit in drillpress (hand drill will work also) and then its chisel and mallet time.
View Gene Howe's profile
Gene Howe
10368 posts in 3396 days
#8 posted 05-10-2013 01:30 PM
I’d do the majority with a forstner bit in a press and clean up with a chisel.
ToddJB
#9 posted 05-10-2013 01:36 PM
Perfect. That totally makes sense. Thank you, Sirs.
And Gene, G.K. Chesterton, in my opinion, has some the best quotes out there.
ToddJB
#10 posted 05-10-2013 01:38 PM
Oh, and by the way, is there a name for this type of joint?
bondogaposis
#11 posted 05-10-2013 01:47 PM
Exactly how I would do it.
-- Bondo Gaposis
View NoLongerHere's profile
NoLongerHere
893 posts in 2644 days
#12 posted 05-10-2013 02:15 PM
a few ideas came to mind:
Why are you using 4×6 legs? they’re HUGE! Any chance you could rip them down to a 4×4 on your table saw?
They don’t really add much structurally and they look too big. You end up with a free 2×4 too.
If you rabbeted out the whole back side – 1 1/2×3 1/2” and screwed your end rails to the front/ back rails, it would be so much easier using a skill saw and a speed square. Multiple cuts 1/4” apart, then chisel/ plane it out.
There’s a better way…..Check this out - I cheated on my 10 long MITRE stand 4×4 legs. (see workshop)
I ripped 6 – 36” – 4×4 legs, made of fir, in half. I cut 3 1/2” off the back half for the top rail and 4 1/4” for the middle 3/4” shelf rail. I glued the same halves back together and you can’t even tell – no time consuming 2×4 dadoes that are too loose or too tight. Prebuild your frames and assemble upside down… takes half the time!
With 6 legs, that’s 12 dadoes I didn’t have to do. Huge time saver and the joints are perfectly tight because they were cut to length on a MITRE box while assembling. Much stronger too.
I also rounded over all the edges with a 1/4” router bit. Add a 2×2 inside for a screw rail to attach top.
Good luck!
ToddJB
#13 posted 05-10-2013 03:03 PM
Thanks for the ideas, Mark!
View Lee Barker's profile
Lee Barker
2170 posts in 2818 days
#14 posted 05-10-2013 03:11 PM
Please permit me two irrelevancies:
1. I’m in on the Chesterton fan club.
2. Thank you Todd for the fascinating optical illusion (or “delusion” as I friend of mine likes to say). Stare at it for a few minutes and you’ll likely see it morph into something even Todd can’t build!
Kindly,
View Loren's profile
10276 posts in 3616 days
#15 posted 05-10-2013 04:37 PM
I usually saw and chisel such notches out by hand. It’s good practice with
hand tools and won’t take too long in soft woods.
Any standard straight router bit with a 1/2” shack will serve okay
for hogging this material. You might want to make a template
out of 1/4” material and use a guide bushing.
