How to move a large bandsaw into garage
Forum topic by cbehnke posted 05-08-2013 03:40 PM 3887 views 0 times favorited 22 replies Add to Favorites Watch
View cbehnke's profile
cbehnke
89 posts in 2793 days
05-08-2013 03:40 PM
I have a large bandsaw being delivered soon (78.5 inch height). The garage ceiling is more than enough to handle it, but the height getting through the garage door is a limiting factor, it’s about 78 inches. And when I take into account the height of pallet the BS will be on, I won’t be able to use a pallet jack to scoot the machine through the garage door.
I can tip the machine, but it weighs 550 pounds and I’d want some type of bracing or mechanical help in that situation.
How have you guys moved tall, heavy machines through low openings.
Ideas, suggestions welcomed.
22 replies so far
View Loren's profile
10477 posts in 3825 days
#1 posted 05-08-2013 03:50 PM
I would take it off the pallet.
View helluvawreck's profile
helluvawreck
32087 posts in 3043 days
#2 posted 05-08-2013 04:01 PM
A good sized man can move a band saw like that right into your garage with a decent hand truck provided it is strapped securely to the hand truck. It would be better for him to have a helper.
helluvawreck aka Charles
#3 posted 05-08-2013 04:32 PM
Keep in mind you’ll be moving it with the table and
perhaps the trunnion removed (about 100 lbs).
I would anyway.
Charles is right. I would take it off the pallet,
strap it to a hand truck and tip it back just far
enough to clear the sill and walk it in.
View b2rtch's profile
b2rtch
4863 posts in 3225 days
#4 posted 05-08-2013 04:38 PM
I cannot explain to you how to do it because it is mainly years of experience that teach you how to do it.
I unloaded a Unisaw from my truck all by myself.
I have been working on very heavy equipment mostly by myself for almost 50 years, this is how I have leaned to do it.
The trick is to use the weight of the load to your advantage, this cannot be explain, sorry to not be more helpful.
You could buy a mover dolly at HF and a hand truck also.
http://www.harborfreight.com/3-wheel-movers-dolly-67208.html
http://www.harborfreight.com/movers-dolly-39757.html
Just be careful to not hurt yourself.
Do you have friends to help you.
-- Bert
View PurpLev's profile
PurpLev
8542 posts in 3825 days
#5 posted 05-08-2013 04:55 PM
get it off the pallet and out of the box outside.
tip it over and lay it on it’s back/side on a dolly and get it in that way. either ask a friend(s) to help you or depending on your physical ability you may be able to do it by yourself as you only need to tip it down and not lift all 550lbs with shear muscle strength. you can also use straps and ratchets to help you with that to reduce the strain on yourself
View Straightbowed's profile
Straightbowed
717 posts in 2475 days
#6 posted 05-08-2013 04:57 PM
you can take a simple crowbar and move that baby all over the place it will take awhile but that is one way to do it by yourself just pry up and scoot the pallet, or get a couple buddies and just manhandle it if I was close to you I would help you but I live in KY
-- Stevo, work in tha city woodshop in the country
View redSLED's profile
redSLED
790 posts in 2069 days
#7 posted 05-08-2013 08:58 PM
Transfer bandsaw to heavy duty dolly. With helper, tip bandsaw down on to second dolley. Roll in horizontal saw on 2 dollies through doorway and place base near desired location. Remove first dolly, setting base down with helper and/or pump jack. Remove 2nd dolly. Lift saw upright and move into final position.
View DS's profile
DS
3025 posts in 2597 days
#8 posted 05-08-2013 09:33 PM
You can either
1) Jack up your entire house to allow the extra room to clear the door then set it back on the foundation.
or
2) What redSLED said. I think that is how mine came through the door, actually.
13635 posts in 3518 days
#9 posted 05-08-2013 09:42 PM
however you do this
DON’T GRAB THE TABLE
TO PULL PUSH OR LIFT
you will just break the trunnions
lay it on its side on the yoke
(the left side that goes to the upper wheel)
and scootch it with a prybar
if you have no other option
even on top of a plank or ply
so you don’t scratch the paint
or drag into concrete floor
Shawn Masterson
1325 posts in 2125 days
#10 posted 05-08-2013 10:36 PM
lay it on its side on cheap movers dollies and roll it in. if you don’t need the dollies any more then just part them out for a mobile base.
View Planeman40's profile
Planeman40
1277 posts in 2938 days
#11 posted 05-08-2013 10:54 PM
This is when you find out how many friends you REALLY have! :)
View quartrsawn's profile
quartrsawn
146 posts in 3390 days
#12 posted 05-09-2013 12:21 AM
As a retired truck driver, I know showing a couple of portraits of Hamilton can work wonders. When you raise the pallet jack it will add another 1 – 2 inches of height. Take it off pallet and “walk ” it in.
-- Nat - West Sayville,L.I., NY
cbehnke
#13 posted 05-09-2013 12:24 AM
quartersawn…I agree. that Hamilton guy works wonders.
View Doug 's profile
Doug
28 posts in 2270 days
#14 posted 05-09-2013 01:25 AM
I use an engine crane or a motorcycle jack to move a lot of my heavy machines. But, im sure you’ve already figured it out from the other suggestions. Good luck
View southernelle's profile
southernelle
19 posts in 2022 days
#15 posted 05-09-2013 01:47 AM
I helped move a 12 door unit into the opening at my house… we used a motorcycle jack. I would lay it down in the truck on it’s side..slid it off onto the motorcycle jack… if there is a problem sliding it… lay it on furniture dollies until you get it to the motorcycle jack.
-- Southernelle
