Noob question on drying and milling lumber.
Forum topic by Button43 posted 05-07-2013 11:02 PM 944 views 0 times favorited 5 replies Add to Favorites Watch
View Button43's profile
Button43
20 posts in 1865 days
05-07-2013 11:02 PM
Hey guys I am about to build a workbench and I have a few questions regarding milling, and drying, of the lumber. I am sure I have this wrong but from my understanding I should get the wood in to my garage and let it acclimate for about a week. From there I should rough mill all the lumber then let it sit and acclimate for another week. From there I can mill it to final dimensions. All the wood I should be getting should be Kiln dried, and I am located in Southern California if that matters.
Is this procedure correct? What is considered rough dimensioning? a 1/8th over? Can/Should I rough cut to length as soon as I get it in to the shop?
I just bought my first planer and jointer, and I want to make sure I have the process correct.
Thanks.
Chris
-- - Chris
5 replies so far
View richardwootton's profile
richardwootton
1699 posts in 1950 days
#1 posted 05-07-2013 11:46 PM
That sounds pretty darn close, you could let it acclimate a little bit longer, rough mill it, let it set for another week or two to further acclimate, then mill to final dimension and be pretty safe. When I rough cut/mill I’ll allow for more than an 1/8th in a lot of instances if I have enough stock for it.
-- Richard, Hot Springs, Ar -- Galoot In Training
View Don W's profile
Don W
18707 posts in 2562 days
#2 posted 05-07-2013 11:47 PM
So, what is the lumber? The process you described would work well for rough sawn. Also, what dimensional lumber are you buying? 2x lumber takes longer to acclimate than 1X, etc.
For a typical bench, with kiln dried limber you can probably start building when you get home. All the gluing and cutting is going to take you enough time anyhow. Also,depending on the bench, the tolerance probably will not need to be that tight.
Button43
#3 posted 05-08-2013 01:20 AM
Thanks for the input.
I am basing the bench off of John White’s New Fangled Workbench. I am going to use Kiln Dried 2X Douglas Fir lumber for the frame. I am going to use some 8/4 S2 Ribbon Mahogany for the top.
If I had, for example, 6” wide by 8’ long 8/4 piece of wood that was ultimately going to be three 5” x 1.5” X 30” pieces wouldn’t I be better off cutting it in to thirds lengthwise as soon as I get home, or should I let it acclimate in it’s 8’ form before doing any rough dimensioning?
-- - Chris
Don W
#4 posted 05-08-2013 01:33 AM
cutting it to length does nothing to help with or hurt the acclimation. How long you should let it acclimate really depends on how dry it is in relationship to your shop.
My opinion is you can start working the lumber as soon as you get it, assuming it hasn’t been stored out in the rain somewhere. Depending on how fast you plan to build this bench (most folks on this forum take weeks or months to complete a bench) you could just build it. I just wouldn’t do the final sizing on the joints until the wood has been in your shop for 2 weeks or so. In reality 2” lumber could take up to a year to really acclimate if the climate change is substantial.
You can go ahead and get things cut to length, glue up the top and even rough cut the tenons etc. Just leave the joints a little on the large size (which you would do anyhow) and when ready to fit, plane or rasp them to size.
When your building you need to plan for movement, even after acclimation, so once that’s figured into the equation, its really not that big of an issue.
When you’re not building, make sure you keep it stacked and stickered so it dries evenly.
Button43
#5 posted 05-08-2013 02:12 AM
That makes sense, I appreciate the sound advice – thank you Don.
Not I need to go do research best practices on building to plan for wood movement.
-- - Chris
