A couple of questions for a project gone wrong using Mahogany
Forum topic by 3fingerpat posted 50 days ago 226 views 0 times favorited 4 replies Add to Favorites
View 3fingerpat's profile
3fingerpat
201 posts in 204 days
50 days ago
Topic tags/keywords: jig mahogany
All, I had a problem today while using some Mahogany I had glued up trying to make a handle for a drawbore pin. I was planing the wood down to size and noticed that there was white stuff in the wood grain as I planed, I had not planed this wood before, so I don’t know if this is normal or not? Any thoughts? Here is a picture:
http://i508.photobucket.com/albums/s326/delaneypj/tool%20cabinet/100_1687.jpg
I also had a problem where I got to the point in the project where I had just heated up the drift pin and was tapping the handle down on top of the drift pin. After the handle was fully seated, I noticed a gap started to appear on the glue line btwn the two pieces I had glued up for the handle blank. Within about 30-60 seconds the two pieces came apart at the glue line, bummer. I had never experience this before where the glue had failed, the pieces had been glued up for 24hrs and I used plenty of glue. Any thoughts? Is there something special to Mahogany that has to be done to it before applying glue? I used Titebond yellow glue and it is not old. FYI, I used the same glue on two pieces of oak earlier this week and that handle also failed. That time it split the handle apart as I was seating the handle down on top of the drift pin, but it failed along some wood grain and not the glue line (it failed because I had drilled the hole in the handle to small for the pin).
Any help or advice anyone could provide would be greatly appreciated, thanks in advance.
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
277 posts in 134 days
49 days ago
I remember reading an article about using the titebond (or anyone white or yellow glue) for making your own edge banding. The theory was to cut your strips, apply the glue, allow it to dry and then you could use an iron to heat set it.
So sounds like the heating of the pin caused the glue to fail, but that is only a semi-educated guess.
-- Rich, WNY, www.nyrockingchairs.com
View FlWoodRat's profile
FlWoodRat
308 posts in 446 days
49 days ago
Pat, what had you planed prior to the mahogany? Is it possible that some residue on your planer knives transfered to the mahognay?
-- Smile. Life can be FUN!
View rhett's profile
rhett
45 posts in 204 days
49 days ago
The white stuff I believe is silica and was transfered to the tree as it was growing. Stain would cover it, but it is not uncommon to be found in mahogany. As far as the glue goes, how long have you had that bottle? There is a definate shelf life for wood glue.
-- http://www.efcabineture.com/ "Experience is what you get, when you don't get what you want"
3fingerpat
49 days ago
thanks for the advice guys.
Woodrat, I forgot to mention I was using hand planes.
Rhett, the glue is less than one year old, so not sure what happened there but I will be trying it again today to see what happens, thanks again.
Bookmark And Share This Page
