| Forum topic by Brad | posted 50 days ago | 364 views | 0 times favorited | 16 replies | ![]() |
50 days ago |
Topic tags/keywords: question mahogany planer resource I picked up a Dewalt 735 planer 2 months ago. Recently I was running some mahogany lumber through it and the feed wheels starting slipping and not feeding the lumber through. They are functioning correctly otherwise but they seem like they can’t get a good grip on the lumber to feed it through all the time. Sometimes they work and at other times they don’t. Although they are always moving. Has anyone else had this issue? Know of a fix or am I doing something wrong here? Just to eliminate some suggestions -- Great Coffee= 8oz strong coffee, 1tbsp brown sugar, 1tbsp 1/2&1/2, 1 heaping teaspoon mahoganny |
50 days ago |
Check the height of the infeed and outfeed tables. If they are not on plane with the actual “work surface” of the cutter heads this might cause a problem. (co-planar) . Another guess would be to clean the feed rollers with denatured alcohol. Mahogany is fairly oily and they might actually be slipping. I know you noted that they were “clean” but . . .(Visibly clean v.s. Actually clean) Also, do you notice any additional snipe at the ends? Does it happen only on long stock? Only on thin stock? Does it occur if you INCREASE the depth of cut? Any addtl. info could help to nail this down. |
50 days ago |
Brad, I have a 733 but recently had the same problem and it ended up being one of the feed rollers had to be replaced due to cracking. It looked clean from where I could see, but once I took it apart, I found that there was numerous cracks througout the roller. Replacing that one roller fixed the problem, so I would recommend taking a very close look for that issue. Does the same problem exist when you try other woods? -- "You get what you inspect, not what you expect" |
50 days ago |
Ihave the 735. The problem you describe is usually my first indication that the knives are going dull, or they are loading up. My first step is to follow Grumpy’s suggestion and clean the rollers, if that doesn’t get it, pop the top and remove the blades. If they are loaded, just clean them up and reinstall, if dull, rotate and use the other side. Q -- I don't make sawdust...I produce vast quantities of "Micro Mulch." |
50 days ago |
Great suggestions I’ll get into these tomorrow. 1. No snipe The rollers are slipping because when it stops moving and i have to push the lumber to get it going again i see a small amount of rubber dust almost like a little burn out. -- Great Coffee= 8oz strong coffee, 1tbsp brown sugar, 1tbsp 1/2&1/2, 1 heaping teaspoon mahoganny |
49 days ago |
i have an older ryobi that does the same thing. When it does this I know it’s time to give the rollers a good cleaning. they will load up with dust and oils from the wood. you can also try waxing the bed of the planer with a furniture wax. the bed will get small scratches that may catch the wood. I’ve tried to get into the habit of cleaning my planer after each heavy use to keep this from happening during middle of a project. -- Joey, Magee, Ms http://woodnwaresms.com |
49 days ago |
I have a newer one in good shape and this happens once in a while. I always stand by to “help” a little. I think it just depends on the smoothness of the board as well as some of the other things listed earlier. With a little dust and a freshly planed surface certain types of wood will tend to slip a little. -- Check out my new website! http://www.theeasellife.com |
49 days ago |
I had the same problem as you changed the rollers easy job spares no problem to come by I would check this sometimes they can get torn up Alistair -- excuse my typing as I have a form of parkinsons disease |
48 days ago |
Well it seems that it was just the mahogany i was running through there. I ran about 20 feet of walnut and poplar tonight and didn’t have any problems. Only once or twice it slowed up so i just nudged it and it kept on truckin. I’m still going to break it down in clean all the internals. Thanks for all the help guys lumberjocks rocks! -- Great Coffee= 8oz strong coffee, 1tbsp brown sugar, 1tbsp 1/2&1/2, 1 heaping teaspoon mahoganny |
48 days ago |
i have a 733. does anyone have a good tip on how to clean the rollers |
34 days ago |
as an aside, you might also try cleaning and then waxing the tables with either paste wax, top-cote or some such . . .once it is applied and completely dry you shouldn’t have any problems with whatever finish you apply. You’ll probably sand, plane or scrape before finish goes on any way. |
34 days ago |
What does this have to do with Sal and your earphones? -- Odie, Confucius say, "He who laughs at one's self is BUTT of joke". |
34 days ago |
My dad has one of these and has had it in the shop three times for this issue. We tried planning up a about 12 90” long 5/4 boards this weekend an got to the 3rd board and it started do the same thing described above. So he took it into the shop today, and the service manager agreed to replace it and should have a new one by next week. Needless to say he is tickled pink. Hope you are not having the same problem that he has had. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
34 days ago |
I have same planer. I have had the same problem. Take some thinner and clean the rollers by raising the head to the highest point. change the knives that will help. More often the blades are starting to dull. |
33 days ago |
Same planer – same issues – same answers:
For me this problem is most pronounced with mahogany (dusty) and hard maple (knives must be really sharp). -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
33 days ago |
DeWalt service centers have excellent help – both live technician and videos of common routine fixes. -- Regards, Steve2 |
31 days ago |
OK it’s official, I had the same problem until today. That’s because yesterday I raised the planner to the max. Then I used lacquer thinner on the rollers. They were nasty, but today they were clean. Today the planner worked like new, and not one piece of wood bodged down. Do this before you mess with the blades. -- Odie, Confucius say, "He who laughs at one's self is BUTT of joke". |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1809 |
| Become a sponsor |
124 |
| Become a sponsor |
378 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
