Rolling Pin
« back to Woodturning forum
Forum topic by VegasLee posted 05-06-2013 03:29 PM 890 views 0 times favorited 2 replies Add to Favorites Watch
View VegasLee's profile
VegasLee
2 posts in 1845 days
05-06-2013 03:29 PM
I am looking for the parts to make a rolling pin. Not the wood parts – I will turn those. Is anyone is aware of a prepackaged kit that includes the bearings, axle and end nuts. If there isn’t a pre-packaged kit – any sources for the individual parts would be nice.
I want to have the handles turn.
Any help would be appreciated.
2 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2847 days
#1 posted 05-06-2013 04:07 PM
Nice project idea, VegasLee.
Here’s a fun source for surplus bearings, but be advised that you may end up buying more than that!
American Science and Surplus
There’s a dandy one that’s 7/8 OD and 3/8 ID.
As for the rest, your local Ace or True Value store will have solid rod in various diameters.
I would just have those two hardware bits and then epoxy the rod into the handles. I’d grind some recesses in the rod so the epoxy would create a mechanical as well as chemical bond.
I would really appreciate your charting your progress on your Projects page. I could get interested in taking a run at this. Never occurred to me before.
Kindly,
View robert triplett's profile
robert triplett
1566 posts in 3101 days
#2 posted 05-07-2013 12:31 AM
I looked for these kind of parts a few years ago when I was making rolling pins. I did buy a cheap rolling pin and used the hardware in my own pin! For others, I ended up using a dowel that was loose in the handle and glued into the ends of the body. good luck. I’m with Lee. Keep us appraised of your progress.
-- Robert, so much inspiration here, and now time to work!!!
