Scheppach Deco Flex scroll saw
« back to Scrollsawing forum
Forum topic by Tim posted 05-06-2013 11:40 AM 2839 views 0 times favorited 5 replies Add to Favorites Watch
View Tim's profile
Tim
273 posts in 1763 days
05-06-2013 11:40 AM
Topic tags/keywords: scroll saw question
Is this a good saw for a beginner for under $200 ?
-- No tree was harmed in the making of this project...... wait a minute, yes there was, uh oh
5 replies so far
View Pdub's profile
Pdub
923 posts in 3085 days
#1 posted 05-06-2013 09:11 PM
Hi Timzo, I have never used the Scheppach but looked online for reviews. Most said it was a decent saw for the money. One thing I noticed is the blade clamps. They will not be very user friendly if you do alot of fret work. If you could find a saw with a blade clamping system, it makes blade changes alot easier and faster. If you buy one, make sure it can use pinless blades. There are several out there for under $200. I would do a little more research before buying. If possible, buy one that doesn’t require the use of a wrench each time you make a new inside cut. The Scheppach looks like it requires a wrench each time.
Paul
-- Paul, North Dakota, USAF Ret.
View sgv's profile
sgv
266 posts in 1798 days
#2 posted 05-06-2013 09:34 PM
Timzo, I have used cheaper scroll saw, they do work but have a lot of vibration, my first was a dunlap, pined, tough to change blades, next cam a delta $199 tough to change blades, and thing would walk the bench around the garage it vibrated so much, now I have a dewalt 788 LOVE IT, no vibration at all easy to change blades, I can cut while my wife is asleep!!! my two cents any way, hope it helps :)
-- Tite Lines, May the wind be at your back
View jordanp's profile
jordanp
1086 posts in 1846 days
#3 posted 05-06-2013 10:02 PM
Im no scroll saw pro but i have an old (25+ YEARS) craftsman 16” directdrive that has been great, blade changes with a hand turn of a knob. Ive seen these out there on cl and other swap sites pretty cheap
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
View Skiedra's profile
Skiedra
259 posts in 2197 days
#4 posted 05-19-2013 05:08 PM
Hey, Timzo,
I have this exact scrollsaw for a couple of weeks now. It’s OK. Some of my remarks:
+ nice working capabilities
+ normal operating noise
+ large “throat” depth
+ takes both pin and pinless blades
+ the addons and the rotary tool is a perfect addition to a beginner scrollsawer. So you do not need to buy a dremel or any similar rotary tool
- a bit painful process to change the blades
- you seriously need to bold it down, otherwise it moves
- attached rotating bit are a bit too “toyish”, but does some light sanding/drilling easily
- to change the blades, you have to tilt the table, and it takes effort to re-adjust the correct 90 degree angle
For this price and as a starting scrollsaw, it fits me perfectly.
Skiedra
#5 posted 05-19-2013 05:08 PM
Hey, Timzo,
