Doing research for a project
Forum topic by sandhill posted 05-06-2013 05:48 AM 848 views 0 times favorited 6 replies Add to Favorites Watch
View sandhill's profile
sandhill
2128 posts in 3833 days
05-06-2013 05:48 AM
I am gathering information for building an exterior front door for our home I live in VA so that is the environment I have to deal with but never did this before so I am trying to get all the information I can before I start. Has anyone ever built one? What kind of things do I need to consider? I know I need to figure on expansion and contraction but how much? I want to use QS White Oak and I will also have stained glass panels in the top half with tempered glass both inside and outside. It seems straightforward but I just don’t want to overlook anything. Thanks in advance
View GaryL's profile
GaryL
1099 posts in 2740 days
#1 posted 05-06-2013 11:11 AM
QS white oak is an excellent choice do to it’s stability.
The best suggestion I can make is to rough cut all your parts within a 1/4” or so of final size and let them sit for a week or more. Basically try to get all the stress and movement out of the material as best as possible before final milling and dimensioning. I even watched a video where the craftsman actually dropped the material from about 6’ to help relieve internal stresses. Can’t say that I’ve ever tried that one yet.
Hopefully then you can be fairly confident that the door will stay flat with minimal warping or twisting.
I am assuming your doing some type of panels on the lower section?
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View Bluepine38's profile
Bluepine38
3379 posts in 2994 days
#2 posted 05-06-2013 02:22 PM
Check out Shipwrights “All weather front door” it is the best example that I have seen unless you can get
some of that fabulous wood that Benji uses for his doors.
116913 posts in 3486 days
#3 posted 05-06-2013 02:37 PM
My father-in-law made doors and windows for 60 years. One trick he used was to finger joint short sections of wood (8”-12”) for the stiles and then veneer 1/4” material on both faces and on edges. This makes a very strong and stable door.
sandhill
#4 posted 05-06-2013 02:39 PM
GaryL Yes I will have panels in the bottom. I found a design I liked that someone here at LJ did so I may see about using that design. http://lumberjocks.com/projects/70765 I will drop him a line to see if he has some suggestions as well.
a1Jim Very good idea I had not thought of that, it would keep the cost down as wrll. What wood do you think would be the most stable?
James101 I have not concidered the fogging aspect, Maybe I can just use the stained glass I will look into that.
Bluepine38 Here is the look I am going for
Thank you keep those ideas coming.
View AandCstyle's profile
AandCstyle
2979 posts in 2166 days
#5 posted 05-07-2013 12:25 AM
The May/June 2012 issue of FWW had an article on making an A&C style entry door. If you are a member of their site you can use this link. It should answer most of your questions.
-- Art
sandhill
#6 posted 05-07-2013 02:49 AM
I am not a member, only the free site.
