out feed table
Forum topic by sgv posted 05-05-2013 09:56 PM 1178 views 0 times favorited 12 replies Add to Favorites Watch
View sgv's profile
sgv
266 posts in 1976 days
05-05-2013 09:56 PM
Ok this may have bin discussed before but here go”s , out feed table doubling for a work bench? pro’s, con’s
My new shop will be about 14×18 and I want to utilize the space the best I can. Tools I will have are, TS Grizzly 0690, bandsaw 14in, bench dog router table, 788 scrollsaw, dust collector, bunch of wood working stuff, This is my first reel shop,(not a garage shared by my car, not a wood shed with lawn equip). a reel room, just want to do it right.
Thanks in advance!!!
-- Tite Lines, May the wind be at your back
12 replies so far
View Tugboater78's profile
Tugboater78
2749 posts in 2275 days
#1 posted 05-05-2013 10:05 PM
Sounds like a plan, depends on height of tablesaw, and whether u use power or handtools on tour bench from my understanding.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View Bill White's profile
Bill White
5008 posts in 4044 days
#2 posted 05-05-2013 10:14 PM
Reel or real?
Do ya want to make the outfeed double/triple for all machines?
Sounds like a good selection of power tools. Just help us understand what you want.
Bill
-- bill@magraphics.us
Tugboater78
#3 posted 05-05-2013 10:27 PM
Its always good if all flat surfaces can be at the same level
View hotbyte's profile
hotbyte
991 posts in 3059 days
#4 posted 05-05-2013 10:32 PM
I made a small 2’ X 4’ outfeed table using plywood ‘L’ legs and solid code top turned longways coming off saw. I took the parts from an old Black and Decker Work Mate and mounted to one end to serve kind of like a tail vase, mounted an el-cheapo Bessey vise one side closest to saw. This actually arranged the vises like a lefty workbench but I didn’t realize it when I set it up.
I also put my Triton router on a Rockler aluminum plate in middle of it.
My shop is similar sized to yours (13X24) and this little table works great for me. I lay a piece of luan over top when gluing or finishing to protect the top and router.
I have a narrow, full width fixed outfeed support built onto back of saw and placed the outfeed table/workbench/router table about 16” away from saw. This lets me get around all 4 sides of table when assembly/finishing projects. I’m going to make a small “bridge” to span this space for can be easily set in place when needed. Probably use luan with some 1X3 stifiners on underside and some type of cleats to hold it on place and level to saw/table. Then, when I need to get all around table, I’ll just remove the bridge. I tried moving table back and forth and that got old :)
View sgv's profile
sgv
#5 posted 05-05-2013 11:35 PM
Thanks hotbyte i will consider some of those options just trying not to have wasted space.
(also REEL OR REAL I also fly fish tie my own flies and have made a split bamboo fly rod I just cant spell!!!!!)
tugboater from what I have seen the Grizzly 0690 is 34in tall that is just about counter high.soooooo i think it could work:)
View muleskinner's profile
muleskinner
897 posts in 2520 days
#6 posted 05-06-2013 12:09 AM
Every flat surface in my shop eventually ends up doubling as a work bench.
-- Visualize whirled peas
View gfadvm's profile
gfadvm
14940 posts in 2773 days
#7 posted 05-06-2013 02:02 AM
sgv, look at my shop vid. I use my workbench as my outfeed table and really like it. I raised my tablesaw just above the bench so the miter gauge/sled runners would clear the tabletop as I didn’t want to route slots in my bench. Works well for me.
View MT_Stringer's profile
MT_Stringer
3173 posts in 3314 days
#8 posted 05-06-2013 03:26 AM
I have almost the same tools and work in a one car garage. Check out my work bench/outfeed table/assy table. It is the only thing level in the shop (besides the table saw).
Hope you get some ideas that help.
Mike
View nwbusa's profile
nwbusa
1021 posts in 2370 days
#9 posted 05-06-2013 08:14 AM
Yep.
-- John, BC, Canada
View sgv's profile
sgv
#10 posted 05-06-2013 05:01 PM
Thanks to all I will check out the vid
View REO's profile
REO
929 posts in 2157 days
#11 posted 05-07-2013 04:02 AM
The most safe way for me to insure work bench area is to disassemble it after use or it becomes a shelf full of ???..well things you know.
View sgv's profile
sgv
#12 posted 05-07-2013 11:50 PM
REO yes I know all kinds of ????? stuff!!!
