Forum topic by Preserved | posted 05-05-2013 10:41 AM | 2333 views | 0 times favorited | 7 replies | ![]() |
Topic tags/keywords: counter miter bolt edge grain Hi Everyone, I’m building a new kitchen counter top and would love some advice on joining the sections. The top will be constructed of edge grain glued maple strips. I’ve built a top for our kitchen island and it turned out great! I’ve decided to build this is three sections (see attached photo) and I’m wondering the best way to join the three sections. My first thought was to just glue the sections together with TB3. Then I started thinking the overall span may be too much for the glue joints so now I’m thinking of using what I’m calling “miter bolts”. Does this sound like a good idea? Anything better? Anyone have a miter bolt setup they really like? Thanks for your help. Preserved. |
7 replies so far
#1 posted 05-05-2013 10:45 AM |
I should also add that the finished top is 40mm thick. I should have enough room to use the bolts. Also, this is the island top I just finished: Preserved |
#2 posted 05-05-2013 03:04 PM |
You might run into trouble with different amounts of shrinkage doing it like that. That can be avoided by mitering the corners at 22.5°. I have a worktop mitering jig with the template for sinking the worktop connector bolts. Nothing special, bought it off ebay. It’s a system that works very well, use biscuits between bolts to aid alignment. You might find this interesting, I posed a similar question not so long ago. http://lumberjocks.com/topics/45055 |
#3 posted 05-05-2013 03:35 PM |
The bolts are ideal because they will in fact allow differential contraction and expansion. There are the cheapie ones, just a 1/4” bolt with a threaded block and a dummy block. the nicer ones use a millimetric hole, likely what you’re thinking of. Using these, and dry biscuits for alignment, your grain direction differences will not be a concern. You can glue up the corner piece with aesthetics as the only driver. Beautiful work on the island, BTW. You make us all proud! Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#4 posted 05-05-2013 03:49 PM |
I agree with Lee -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
#5 posted 05-05-2013 05:06 PM |
Get the ones that fit in a 1 3/8” hole on either side of the joint. Lee Valley has ‘em for about $2.80/10 units. -- bill@magraphics.us |
#6 posted 05-06-2013 12:22 PM |
Thanks guys, I appreciate the advice. I don’t think I’ll go with the 22.5 degree miters since I’ve got some parts of this built already and didn’t account for the extra length from a 90. Looks like that would have been a great option though. Looks like it worked great for the other project in the above link. And thanks for the links to those connectors…what would we do without the internet. Remember catalogs? Preserved. |
#7 posted 05-06-2013 11:57 PM |
If you have countertop shop locally, ask about their drawbolts that they use for joining preformed plastic laminate countertops together with. Sometimes the big box stores carry them if they sell the countertops. I have used them in the past for joining solid wood countertops together. All you need is a router with a straight bit and a 7/16 open end wrench. Usually 3 to 4 drawbolts per joint will do it. -- frosty |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28056 |
CNC Woodworking
212 |
Hand Tools
5407 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
