need advice for glue
Forum topic by jeffswildwood posted 05-05-2013 12:43 AM 747 views 0 times favorited 4 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3056 posts in 1947 days
05-05-2013 12:43 AM
Topic tags/keywords: question
Just finished a project and have all the parts ready for assemble. I found out one of my panels out of 1/8th birch ply warped a little. It has 3 coats of poly on it and would be glued to an untreated surface. Can I use titebond II on this to hold it down? Will titebond work on a polyurethane surface? Maybe scratch the surface? Its the inserts for my treasure chests. http://lumberjocks.com/projects/80429 any help appreciated!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
117063 posts in 3547 days
#1 posted 05-05-2013 01:03 AM
If your doing frame and panel you don’t glue the panel in place,because of wood movement.
jeffswildwood
#2 posted 05-05-2013 01:14 AM
Jim these are the inserts behind the sides. Hide the kreg screws and fill in the spaces for a 3D look. should be no movement. usually the tray shelf hold it all tightly and will on top this time but the bottom flexes. ??
#3 posted 05-05-2013 01:55 AM
Solid wood always moves by taking on moisture or drying out . If it’s ply that’s another matter.
I would guess the bottoms flexing because of wood movement, did it bow when you first put it in? How would you feel about brass screws with elongated screw holes.
jeffswildwood
#4 posted 05-06-2013 11:39 PM
Jim, I went with the glue on the ply. Answered my own question, does NOT stick well on a polyurethane surface. But did stick long enough to get my screws in holding all in place flat and smooth now. I had no problems with the bottoms just a piece or two of the birch 1/8 in plywood. I drilled the shelf rests and counter sunk the holes to hide the screws and this worked great. Thanks for taking the time to assist me in this, I appreciate it. You should have heard those glued panels popping as the screws drew the birch ply down flat.
