Repairing a crack
« back to Joinery forum
Forum topic by donaldmee posted 05-04-2013 12:31 PM 950 views 0 times favorited 4 replies Add to Favorites Watch
View donaldmee's profile
donaldmee
65 posts in 2775 days
05-04-2013 12:31 PM
Topic tags/keywords: question trick tip refurbishing joining
Hi fellow LJ, I have a quick question. A client sent me a pic of a table I finished recently and a crack opened up in it on one end. There already was a small check but now has opened up about 1/8” more. My question is. Can I use a set of clamps to pull it back closer and put in some bow ties to hold it in place and stop it from cracking more?
-- donald mee
View SnowyRiver's profile
SnowyRiver
51457 posts in 3386 days
#1 posted 05-04-2013 12:36 PM
Yes, a bow tie will work to stop the check from opening further You also could try putting epoxy into the crack and if you can pull it together without causing further cracks, it may hold it closed also.
-- Wayne - Plymouth MN
View Bluepine38's profile
Bluepine38
3379 posts in 2991 days
#2 posted 05-04-2013 02:43 PM
I think the check became a crack because of the normal drying of the wood. Could be because of the move
from your shop to a house with a different environment, or just the lower moisture of the air during winter
months that is normal. You could try to fill the crack with epoxy, but I would not try to pull the crack shut as
that would cause stress on other parts of the wood and create new problems. Just my opinion, and I have
been known to be wrong.
View Timberwerks's profile
Timberwerks
360 posts in 3067 days
#3 posted 05-04-2013 02:52 PM
Yes, a butterfly will do the trick. Don’t pull the wood together though, set in a butterfly or two as is. Try to make butterfly 1/2 to 2/3’s the thickness of top.
-- https://www.facebook.com/pages/Timberwerks-Studio/126415221682
View Jeff_in_LSMO's profile
Jeff_in_LSMO
347 posts in 2246 days
#4 posted 05-06-2013 01:41 PM
I’m not a professional so I won’t weigh in on the repair, but Fine Woodworking had an interesting trick a few months ago involving a shop vac to suck glue down into cracks. They put the glue on one side of the crack, put the shop vac on the other side, and turned it on. I haven’t tried it yet, but apparently it sucks the glue right down.
Not sure about a 1/8” crack. That seems like a very shallow crack to try to pull together. I would be afraid that the force required to pull the wood back together would be enough to crush the cells, which will cause future checks. I’m for the idea of putting in a butterfly but not repairing the check. If you still have some of the scrap lying around, maybe cut a little wedge and use that to fill the crack. I guess this would require refinishing that area, but it would avoid causing additional stress in the wood. Crap, I weighed in on the repair.
Regardless, I am a big fan of your work.
