R4512 Blade Washer -- Difficult to remove
Forum topic by fstellab posted 05-03-2013 08:37 PM 1474 views 0 times favorited 9 replies Add to Favorites Watch
View fstellab's profile
fstellab
86 posts in 1987 days
05-03-2013 08:37 PM
Topic tags/keywords: question tablesaw r4512 blade washer r4512 alignment
Hi Folks,
Over time I have noticed that the blade washer was getting more difficult to get on and off.
Recently, I needed to change the blade; its been several weeks since the last time I switched the blade;
I had a really hard time getting it off, and I could not get it back on.
I did not have another Ridgid Blade washer. I had some Boche blade sabllizers, I thought about using one of them
but decided it was not a good idea. So I clamped the washer to my drill press, and just shaved it a bit with a cone shaped grinder. After that it slipped right on.
I then did a full table saw tune up, did all the alignment checks, all was fine.
I ordered a Ridgid blade washer and and nut, $50 with shipping.
Is this normal ? Should I be worried ?
Thank so much
-Fred
-- Fred Stellabotte (kamado@comcast.net)
9 replies so far
MrUnix
6322 posts in 2100 days
#1 posted 05-03-2013 08:47 PM
Don’t know if it’s normal, but I would be worried if I paid $50 for just a nut and washer!
View Surfside's profile
Surfside
3389 posts in 2075 days
#2 posted 05-03-2013 08:55 PM
Where did you purchase those ?
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View crank49's profile
crank49
4029 posts in 2872 days
#3 posted 05-03-2013 09:01 PM
10% of the cost for a whole saw for just a washer and a nut; from China no less.
Any 5/8 arbor washer from any brand of saw should work.
Same for the nut. Shop around.
Who ever you bought those parts from is in serious need of some competition.
fstellab
#4 posted 05-04-2013 02:41 AM
Hi Folks,
I purchased them here:
http://www.ereplacementparts.com/ridgid-r4512-inch-table-saw-parts-c-7929_8171_162373.html
Look at part A-65 and A-66 plus shipping came to $48
Does anyone have any Idea what happen to my initial blade washer ?
View RussellAP's profile
RussellAP
3103 posts in 2188 days
#5 posted 05-04-2013 03:48 AM
The initial blade washer was likely dirty with spatterings of sap and water from wood you cut. A little denatured alcohol would likely cleaned it up enough to slip on. I’d cancel that order and use the nut and washer that came with it.
View Bluepine38's profile
Bluepine38
3379 posts in 2986 days
#6 posted 05-04-2013 02:55 PM
Sounds like Ridgid used a cheap washer, and the action of tightening the nut against the washer has squeezed
the metal enough that it spread out and closed the opening, drilling the hole opening back to the original size
cured your problem. Those washers are supposed to be with precision parallel sides to keep the blade aligned
properly, and be hard enough that they will not deform from normal tightening. Have you been overtightening
the nut?
View MrRon's profile
MrRon
4627 posts in 3145 days
#7 posted 05-04-2013 04:24 PM
You overtightened the nut.
View Howie's profile
Howie
2656 posts in 2824 days
#8 posted 05-04-2013 10:13 PM
Fred: you need to cancel that order fast. You’ve been had.
Don’t tighten the washer so tight. If it’s stuck a little wd40 will help.
-- Life is good.
crank49
#9 posted 05-06-2013 12:33 AM
For what it’s worth, my Craftsman 21833, which is the same saw as the Ridgid 4512, has a washer I can’t get off at all; the back one. I discovered this when I was going to try some blade stabilizers. That was before I found out everyone else with these saws, at that time, had the same alignment problem I had.
I’m really not at all surprised the washer on these saws is inferior. The whole saw is a POS as far as I’m concernerd. I know exactly where I’d like to shove mine.
