Surface rust on Jointer tables - a problem or not??
Forum topic by garberfc posted 05-02-2013 01:05 PM 3383 views 0 times favorited 8 replies Add to Favorites Watch
View garberfc's profile
garberfc
57 posts in 2128 days
05-02-2013 01:05 PM
Topic tags/keywords: jointer rust
Hello all,
I’m in the market for a used jointer and I’m looking at one on CraigsList. I’m just concerned about the light surface rust.
IMHO I’ve always assumed that rust can’t be removed, only halted. The orange tint can be removed, the pitting lubricated, but the pitting remains…
In the pictures from the listing (below), how severe do they look? Also, would they affect the performance of a 6” 1HP jointer?
Thanks in advance,
F
8 replies so far
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2243 days
#1 posted 05-02-2013 01:09 PM
I don’t know anything about the price, but I’d say that surface rust is nothing to worry about. You could probbably have it cleaned up with some scotchbrite and WD-40 in about 15 minutes. Then paste wax to keep rust away. That amount of rust wouldn’t deter me in the least.
For comparison, I picked up this 8” jointer and was able to get all of the rust off, but it took much longer than 15 minutes lol. There is some slight pitting, but it has not effected the functionality of the machine.
View HorizontalMike's profile (online now)
HorizontalMike
7727 posts in 2788 days
#2 posted 05-02-2013 01:20 PM
RustFree works, but be aware to NOT spray it directly onto the metal surface or it will leave an ugly ‘splatter’ mark that will remain. Always use a rag to apply it.
All that said, RustFree does seem to help prevent further rusting. It seems to form a gray colored film that is LESS prone to rusting. The cast iron can still rust, but not quite as easily. So always follow up with Johnson’s Paste Wax or similar. My 2-cents…
View toolie's profile
toolie
2101 posts in 2502 days
#3 posted 05-02-2013 01:22 PM
those jet CI tables will clean up fine, they are really not in bad shape. here’s the before and after of the top to a unisaw i refurbished:
before:
after:
also, this video provides some useful tips on restoring cast iron surfaces:
http://www.youtube.com/watch?v=MSJjN8jvdp4&feature=relmfu
garberfc
#4 posted 05-03-2013 01:26 PM
WOW, nice job restoring the unisaw! Even cleaned up the miter gauge slots…
Thanks for the info.
BinghamtonEd
#5 posted 05-03-2013 01:34 PM
Yours doesn’t look like it will require it, but if you have a large surface to do, I’ve cut circles out of scotchbrite, they fasten right on to a ROS. Don’t overwork it, though, and don’t focus on any one spot.
View Marcus's profile
Marcus
1161 posts in 1893 days
#6 posted 05-03-2013 02:15 PM
Like others have said, the surface rust on that jointer looks very minor to me. I would not be put off by it. I would however point it out 20 times when haggling over the price!
View muleskinner's profile
muleskinner
896 posts in 2310 days
#7 posted 05-03-2013 02:35 PM
If the price is right (seems a little high to me) I wouldn’t give that rust a second thought. I was given an old 6” Delta that had a little more rust than the one you’re looking at. A little bit of scrubbing with some steel wool and WD40 and it cleaned up fine. Like Ed’s, it had a little bit of pitting but the beds are flat and parallel. That’s all that matters. Sharp knives and flat beds. Who cares if it doesn’t shine like the top of the Chrysler Building?
-- Visualize whirled peas
View Loren's profile
9769 posts in 3522 days
#8 posted 05-03-2013 04:25 PM
A machine generally has to be left exposed for a long time to get
major pitting. Oxidation forms on cast iron and this coating
actually protects the iron underneath from pitting.
Rust is almost never a problem in machinery that has
been stored indoors. Just wire brush it off, wax and go
to work.
