Issues with 80 grit sandpaper on drum sander
Forum topic by Alan72 posted 05-01-2013 06:30 AM 1325 views 0 times favorited 4 replies Add to Favorites Watch
View Alan72's profile
Alan72
218 posts in 2272 days
05-01-2013 06:30 AM
I bought my Jet 16/32 used,it came with 80 grit paper. I never had any issues until I replaced the paper with a new 80 grit roll from a new box. I ran some maple through the drum sander and then used the ROS going through the order 100-220 grit paper. SO should I start off the 100 grit paper on the drum sander or did I miss something when I was sanding with the ROS. What grit paper do you keep in your Drum sanders?
View Bill7255's profile
Bill7255
428 posts in 2523 days
#1 posted 05-01-2013 12:19 PM
I don’t use 80 grit anymore. I use 120 90% of the time and some finer grits on occasion. I found 80 grit was hard to wrap and left some deep sanding marks. I suspect it is because I don’t seem to be able to wrap it as tight. 100 grit is probably ok, but consider to do most of the sanding with 120 grit.
-- Bill R
View toolie's profile
toolie
2148 posts in 2867 days
#2 posted 05-01-2013 01:03 PM
i’d only use 60 or 80 for getting surface paint off reclaimed stock. if i am sanding machined parts, i start at 100.
View TheDane's profile
TheDane
5575 posts in 3902 days
#3 posted 05-01-2013 01:08 PM
+1 for toolie … I start at 100 and work up to 340 on the drum sander then finish the gits (to 600) with a ROS.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3397 days
#4 posted 05-01-2013 01:12 PM
I start at 120.
-- jay, www.allaboutastro.com
