Bits get stuck in router collet.
Forum topic by firefighterontheside posted 04-30-2013 01:34 AM 4431 views 0 times favorited 24 replies Add to Favorites Watch
19623 posts in 2096 days
04-30-2013 01:34 AM
I have a hitachi router that I like, but the bits keep getting stuck in the collets. The half inch collet is the worst. Does anyone have a solution for this or is it a bad design.
24 replies so far
View CrazeeTxn's profile
CrazeeTxn
151 posts in 2190 days
#1 posted 04-30-2013 01:37 AM
Depending on use and age, it may be time for a good cleaning. Maybe not so much of the collet as the bits themselves. A little simple green, purple power, or what have you and clean the shafts up. Also, you can take the collet off and blow it out and see if that helps.
View MichaelR's profile
MichaelR
42 posts in 2669 days
#2 posted 04-30-2013 01:40 AM
Cleaning usually takes care of it. Also, when you put in a bit slide it all the way down and pull it back about 1/8”. This gives you a little room to “LIGHTLY” tap the bit to break it loose if it wants to stick again.
View scotsman9's profile
scotsman9
134 posts in 2128 days
#3 posted 04-30-2013 01:43 AM
Not dismissing you or your quandary; but a helpful hint would be to type into the search bar; “router bit stuck”. More solutions than you can shake a bit at.
Hope this helps.
-- Just a man and his opinion.
Shawn Masterson
1325 posts in 2188 days
#4 posted 04-30-2013 01:54 AM
I would check the collet it’s self. It maybe smashed from over tightening it to many times.
#5 posted 04-30-2013 02:15 AM
Thanks for the replies I will consider all.
View Planeman40's profile
Planeman40
1331 posts in 3001 days
#6 posted 04-30-2013 03:44 AM
This is a common occurrence with collet-type holders in various machines. Collets are excellent at holding tooling accurately and securely, however due to the collet being forced into the taper of the collet holder, the collet often doesn’t easily release the tool easily. This is remedied by, after unscrewing the collet holder, tapping the tool bit back INTO the collet with a soft-face hammer or with a piece of wood held over the front the tool bit so as not to damage it. This shoves the bit and collet AWAY from the taper of the collet holder, releasing the bit.
The best way to easily accomplish this is by NOT inserting the tool bit all the way to the bottom of the collet, thus leaving some room to tap the tool bit back into the collet when removing it.
Planeman
View kdc68's profile
kdc68
2692 posts in 2516 days
#7 posted 04-30-2013 03:56 AM
+1 Planerman40....bottoming out the bit and getting it stuck in the collet is a PITA…
-- Measure "at least" twice and cut once
117417 posts in 3817 days
#8 posted 04-30-2013 04:01 AM
Like everyone else said don’t put the router bit all the way down in the collect.router but shanks are tapered so the shank closest to the cutter is wider than the rest or the shank.
View REO's profile
REO
929 posts in 2314 days
#9 posted 04-30-2013 06:56 AM
once in a while wipe the outside of the taper with a rag containing light oil. not to the point that it runs off just a coating. it will take less to get the bit tight while increasing the actual grip on the bit. I hadn’t seen a router where the taper is toward the nut most of the tapers are in the spindle. driving the cutter into the collet IS driving it toward the taper but most of the collet and nut assembly’s now have a shoulder for drawing the collet out of the taper. I am not sure of your particular router. what happens if you try to completely remove the nut? I have found that a tap on the side of the bit once the nut is loose with a block of wood is very effective for stuck bit removal.
5240 posts in 2733 days
#10 posted 04-30-2013 11:31 AM
Does that have a self releasing collet? I know The old Freud, the Milwaukees, and the PC routers all release after you crank the nut out a few more turns after the initial loosening. Maybe some other brands work that way as well.
#11 posted 04-30-2013 12:06 PM
I never put the bit all the way in. It does have the self releasing deal where you have to keep turning even after it gets loose the first time. The deal is that I can take the collet and nut all the way off the router and the bit is still stuck in the collet. Then I have to use something to “tap” the bottom of the bit to get it to come out of the collet. I believe yesterday I may have damaged some threads on the collet nut. I think I am going to replace both collets and nuts, but this has been a problem since the first time I used the half inch collet so it wasn’t a problem of any kind of build up or age. After some searching, it appears to be a problem with the hitachi collets.
#12 posted 04-30-2013 12:08 PM
As far as overtightening goes, I have had the problem of a bit coming partly out of the collet during use so I am leary about not tightening as much.
View Kaleb the Swede's profile
Kaleb the Swede
1881 posts in 2209 days
#13 posted 04-30-2013 12:22 PM
If you have a scraper or a junk thin saw blade, put that in the opening that goes all the way across collet. Lay it down on a flat surface and push, and the bit comes out. A collet I had kept doing that and that seemed to work for me. It’s much easier than using wrenches and I won’t damage either the bit or the collet then. On askwoodman.com Mr. Allan Little explains it much better than I do, and he has a video
-- Just trying to build something beautiful
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3398 days
#14 posted 04-30-2013 12:23 PM
Never tighten it all the way in. If it sticks, tap it in further…which releases the collet.
-- jay, www.allaboutastro.com
View stefang's profile
stefang
16214 posts in 3574 days
#15 posted 05-01-2013 07:51 PM
Sounds like a bad collet to me.
