I think need a new drill bit set
Forum topic by Allanwoodworks posted 04-29-2013 08:38 PM 1271 views 0 times favorited 9 replies Add to Favorites Watch
View Allanwoodworks's profile
Allanwoodworks
112 posts in 2715 days
04-29-2013 08:38 PM
Topic tags/keywords: drill bit set
Hello,
So I am thinking of getting a set of brad point drill bits. Right now I have a small set of 5 from grizzly and they have done well, but I am thinking of stepping it up to a larger set. Is this something I need or will most of the bits just sit in the case and only use 5 of them. Please let me know what you think and any set that are a good purchase as I know there are a lot of cheep bits out there. Let me know your options.
Ty
-- Ty, Up in Washington
9 replies so far
View crank49's profile
crank49
4028 posts in 2845 days
#1 posted 04-29-2013 10:09 PM
I have a cheap carbon steel, 29 pc set I got at HF for almost nothing. They are okay, but if I could work in the shop as much as I want to I’d get a HSS (high speed steel) set, or grind my own from a cheap regular point HSS set.
The ones I find hardest to get and justify the cost are the larger sizes. I picked up a few from 5/8” up to 1” in 1/8” increments, but they are pricey.
Forstner bits are okay for larger sizes but there are times I prefer the brad point bits. The brad points don’t wander as bad.
View jumbojack's profile
jumbojack
1673 posts in 2498 days
#2 posted 04-29-2013 10:37 PM
I bought an indexed set of brad points from HF, they run from 1/8 to 1/2 by 64ths. I could not live without them. I do a lot of doweling and since most dowels are not to spec, I dont have to worry. I use a dowel sizer and just choose the correct bit.
View Tennessee's profile
Tennessee
2672 posts in 2388 days
#3 posted 04-29-2013 11:52 PM
I bought the brad points from HF, was not happy. Then I found one of those boxes of drills, all brad points, from 3/32 up through 3/8. Sometimes you see them in Woodcraft. You get a few of each size. Titanium coated, they are now my go-to set. If I have to use a bigger bit, I still pull out the HF set and cringe. I’ll use a forstner if the size is right before I’ll use my HF set.
On the other hand, with an often repeated $9.99 coupon, I’ve bought three sets of titanium coated HF 29 piece twist drill sets that go to 1/2”, and they have been wonderful. Go figure.
View Mark Davisson's profile
Mark Davisson
597 posts in 3191 days
#4 posted 04-29-2013 11:57 PM
HF has two different sets of brad point bits – a 5-piece set and the larger one to which jumbojack referred. Seems like they’d be the same quality but they’re not – the larger set is superior.
-- I'm selfless because it feels so good!
jumbojack
#5 posted 04-30-2013 02:38 AM
One of the bits I had in the set had some run out issues. I purchased a single to replace it. All the others are pretty to very good. Oh I had to replace the 1/4” one too but that was through my error. Had it set in horizontal and brought the bit down on the table and bent it. It had a full 1/2” run out. My bad.
View Joshuah's profile
Joshuah
152 posts in 2567 days
#6 posted 04-30-2013 02:51 AM
I actually have forest city brad points. I know you can get them through highland woodworking . I didn’t think I needed a better set then dewalt or Irwin’s from the big box stores, but I am happy with these!
-- -Joshuah
View nwbusa's profile
nwbusa
1021 posts in 2160 days
#7 posted 04-30-2013 04:02 AM
These are really nice HSS brad points from LV. The 28 piece set is not cheap, but is a very complete set.
These carbide tipped bits are great for tougher jobs.
-- John, BC, Canada
View waho6o9's profile
waho6o9
8070 posts in 2451 days
#8 posted 04-30-2013 05:06 AM
Machine grade cobalt bits are good ones as well, but I haven’t found
brad point cobalt drill bits.
Cobalt bits in the avionic industry are top shelf too.
+1 for nwbusa.
View ksSlim's profile
ksSlim
1264 posts in 2764 days
#9 posted 04-30-2013 05:17 AM
IMHO..buy HSS, and replace individual sizes with carbide when the HSS get dull.
-- Sawdust and shavings are therapeutic
