Grizzly G0661 Table saw burning while cutting
Forum topic by Splinter12 posted 04-29-2013 08:02 PM 1744 views 0 times favorited 45 replies Add to Favorites Watch
View Splinter12's profile
Splinter12
55 posts in 2078 days
04-29-2013 08:02 PM
Topic tags/keywords: question
Good day all, this would be my first forum post. I got a grizzly G0661 contractor table saw (2hsp 240volt) a couple weeks back. I have been cutting baltic birch plywood and oak with no burning but have now gone onto hard maple. While cutting the maple I get bad buring and bad saw marks on the fence side of the blade. The other side of the cut is better but not what I would call acceptable. I am aligned to .002” of the miter slot tilting in towards the fence at the far end and I have set my fence to tow out to .010” at the far end. I am using a Freud 50 tooh combo blade thin kerf. The maple is jointed on the side that faces the fence and the maple only looks to have a little tension in it while cutting.
My question would be is the minimal teniosn in the maple (i meen a shift 1/64” of 36”) be enough to cause the burning?
Should I actually bite the bullet and get a full kerf rip balde?
Would a magnetic feather board help?
Is there anyhting else going on here?
I upgraded from my Bosch 4100 and I can’t remember haveing this kind of burning. This is my first wack a full size saw.
Thanks
45 replies so far
View knotscott's profile
knotscott
7980 posts in 3339 days
#1 posted 04-29-2013 08:09 PM
How thick is the maple?
View Mainiac Matt 's profile
Mainiac Matt
7930 posts in 2292 days
#2 posted 04-29-2013 08:24 PM
try parallel to the slot and see if you still have the problem.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
Splinter12
#3 posted 04-29-2013 08:29 PM
Knotscott, the maple is 3/4” thick. The typical 1×6 S4S stuff.
Splinter12
#4 posted 04-29-2013 08:30 PM
SSnvet, I though you were supposed to have the end of the fence go away from the blade slightly to prevenet binding.
View Brandon's profile
Brandon
4152 posts in 2915 days
#5 posted 04-29-2013 08:35 PM
Splinter, I’ve had similar issues with some maple boards that were just so badly tensioned. They were pinching the riving knife after the cut and you’d find rising saw marks on one side. A full kerf blade did help a bit. Also oversize your initial cuts, then make the final cut so that it only takes off a little bit and will be much cleaner.
-- "hold fast to that which is good"
View JayT's profile
JayT
5587 posts in 2174 days
#6 posted 04-29-2013 09:00 PM
Fence toeing slightly out is fine, but .010” is a bit much, IMHO. See if you can get it down to .002” or so.
Another possible culprit could be that the blade needs cleaned.
View kdc68's profile (online now)
kdc68
2649 posts in 2240 days
#7 posted 04-29-2013 09:16 PM
+1 Brandon W...
If you hadn’t had problems before….then it’s probably the maple….Good advice for ripping the piece wider and then making a final cleanup pass
+1JayT...
Less skew on the fence and try a different combo blade or rip blade
-- Measure "at least" twice and cut once
Splinter12
#8 posted 04-29-2013 09:33 PM
kdc68, how is your G0661 treating you? What do you have in terms of dust collection? My shopvac is just not cutting it.
kdc68
#9 posted 04-29-2013 09:38 PM
Splinter12...No issues with cutting like what you are experiencing…. I use thin kerf blades….The dust collection port has plugged up on me once, but that was my fault…...Other than that, so far…so good
View verdesardog's profile
verdesardog
158 posts in 2574 days
#10 posted 04-29-2013 09:44 PM
when ripping, I always cut a bit wider then send the boards through my surface planer on edge for final clean up and dimensioning…
-- .. heyoka ..
kdc68
#11 posted 04-29-2013 09:54 PM
Splinter12...Let us know if you resolved your issue…Other new G0661 owners (like me) may want a heads up…
Splinter12
#12 posted 04-29-2013 09:57 PM
Kdc68 I get a ton of dust on the floor, do you have that issue? I have a ridgid shop vac. Also with the thin kerf blades being .098 at the kerf and the riving knife been .090, have you found a quick way to get them lined up without a lot of trial and error/ losen, adjust set screw and repeat? The .004 on either side of the knife it hard to get right.
kdc68
#13 posted 04-29-2013 10:06 PM
Splinter12....Yeah I get saw dust on the floor…but most goes into the dust port. I will assume that is to be expected with the bottom of the saw open…No big deal to me though….I have the Diablo thin kerf blades and they are .098 as well. I have not had to adjust the riving knive….lucky I guess. When I first got the saw I put on the blade, I checked the gap between the blade and the riving knive by placing a straight edge along the blade (against the teeth and not the body of the blade) and was able to slip a .004 feeler gage in there. I have checked a couple times since and no change. Do you think your riving knive is out of alignment?
View Charlie's profile
Charlie
1100 posts in 2249 days
#14 posted 04-29-2013 10:13 PM
#1 check riving knife alignment. If it is out of alignment such that it is too far toward the left of the blade, it can tend to pull the piece toward the side of the blade (the side facing the fence). The tension in the cut off tries to close the kerf (yes I know it can go the other way too) and the cut off hits the riving knife and basically then tries to pull your GOOD piece toward the side of the blade. I say this because you mentioned it seems to be burning more on the good side of the cut and less on the cut off.
The “toe-out” on the fence is a bit much. My blade-to-miter-slot alignment is within a half a thousandth as best I can measure (I just got lucky) and my fence toe-out is about .003.
I cut a lot of hard maple for face frames last summer and the maple was definitely more finicky about getting things aligned. Cut a piece of poplar… perfect, with no burn at all. Cut a piece of maple the same thickness right afterward… hmmmmm… some burning. I was told by someone (can’t remember who) that the sugars in the maple make it more prone to burning.
Whatever…. once I tweaked the saw to get clean cuts on maple, it seemed to cut everything else better as well.
shrug
it’s wood. :)
Splinter12
#15 posted 04-29-2013 10:18 PM
I’ll “play” a bit more tonight with the suggestions.
Thanks All
showing 1 through 15 of 45 replies
