| Forum topic by USCJeff | posted 546 days ago | 292 views | 0 times favorited | 7 replies | ![]() |
546 days ago |
I should say that this is not my idea. I got the idea from something I read from a magazine or book. I can’t remember the source, but my jig is essentially the same. All you need to do is size a piece of stock to fit snuggly in the miter slot. Mortise a slot as close to the shape of your digital/dial indicator handle as possible. Slide the caliper into the slot. Secure it using a screw from the top. Pick a reference tooth and move the caliper until it touches the tooth. Record the measurement. Rotate the reference tooth to the back and do the same thing. Check the variance in the readings to determine if it is within your tolerances. This could be done for fences as well.
-- Jeff, South Carolina |
