DRilling holes in end grain of plywood.
Forum topic by MrRon posted 04-29-2013 05:42 PM 3748 views 0 times favorited 11 replies Add to Favorites Watch
View MrRon's profile
MrRon
4793 posts in 3265 days
04-29-2013 05:42 PM
Topic tags/keywords: question
I build large scale locomotive models. They can get quite large, like 5’ long x 15” wide x 16” tall. I build them following metal working techniques, but out of wood mostly. I have a situation where I want to drill 1/8” holes parallel to the plies of 1/2” (12 mm) Baltic Birch plywood (11 ply). The holes will go through 1/4” thickness , but centered and parallel (not perpendicular) to the plies. Machine screws will go in the holes to tie it to something else. This is something that I would normally use a metal for, but due to the size of the material, a metal would be too costly. The bolted joint won’t see any great stress. I could use glue, but I want it to be able to be disassembled. Do you see any problem with drilling those holes as I’ve depicted?
11 replies so far
404 - Not Found
2544 posts in 2991 days
#1 posted 04-29-2013 05:50 PM
I don’t see any problem with what you are proposing, especially since the BB ply is void free. The wise thing to do would be try it on a scrap piece first and see how well it works.
View DS's profile
DS
2924 posts in 2442 days
#2 posted 04-29-2013 06:02 PM
The drill bit will want to wander before it gets started. The plys will influence the bit some.
Best to use some kind of jig, or clamp your work into a drill press setup to get the holes drilled just where you want them.
A smaller diameter pilot hole will help a larger bit stay on course too.
My $0.02
View Loren's profile
10476 posts in 3669 days
#3 posted 04-29-2013 06:10 PM
Best way to do it is use a bushing to control flexing of the
bit so it drills on center.
Have you considered threaded inserts?
A threaded insert is bigger so you can use a larger, stiffer
brad point drill which will stay on center better than a little
wiggly 1/8” drill.
View DS's profile
DS
#4 posted 04-29-2013 06:18 PM
Threaded inserts are slick—and a true machine thread.
MrRon
#5 posted 04-29-2013 06:31 PM
Thanks for the replies. I had thought about threaded inserts, but I can go either way; insert or screw and nut. I will experiment and see which works best. I’m thinking an insert would tend to split apart the plies; looking at a 6-32 threaded insert with an OD of 1/4”. There wouldn’t be much meat left. I made a mistake. 12 mm BB is only 9 ply.
#6 posted 04-29-2013 07:10 PM
Also, check out cross dowels (barrel nuts).
View casual1carpenter's profile
casual1carpenter
354 posts in 2497 days
#7 posted 04-29-2013 08:30 PM
Not sure about this myself but I wonder why no one suggested coating the drilled hole with CA glue to sort of harden the area that will form {accept} threads?
View Dan Lyke's profile
Dan Lyke
1520 posts in 4147 days
#8 posted 04-29-2013 11:20 PM
Completely different wood, completely different project, but this weekend we won the Bodega Bay Fisherman's Festival Wooden Boat Challenge with a boat where the seams were joined by drilling and screwing into the center-ply of cheap 3/8” construction ply.
I’d use a proper-sized taper bit and you should have no problems when the center ply is end-grain, it’ll be a challenge when the center ply is side-grain.
View Lee Barker's profile
Lee Barker
2170 posts in 2872 days
#9 posted 04-30-2013 04:29 AM
I like Loren’s barrel nuts idea. That allows for a little oversize holes, in case the bit wanders, but positive attachment. Brilliant.
Kindly,
MrRon
#10 posted 04-30-2013 03:47 PM
Here is a sketch showing what I want to do. This detail takes place in 18 places on the model. The model is of an electric loco used by the New York Central RR. I posted this because barrel nuts won’t in this case. The CA glue is an idea that I can try. The BB is for the frame of the loco which measures approximately 6×50. Alum would be too expensive to use.
MrRon
#11 posted 04-30-2013 04:01 PM
Dan Lyke, Thanks for the pictures; sure looks like fun. I lived in San Rafael from 1966 to 1998 and used to boat on the Bay area waterways. It got to be too expensive for me, so here I am in beautiful Vancleave, South Mississippi.
