Air dried maple moisture content
Forum topic by Seed posted 04-29-2013 07:04 AM 2283 views 0 times favorited 5 replies Add to Favorites Watch
View Seed's profile
Seed
8 posts in 2237 days
04-29-2013 07:04 AM
Topic tags/keywords: moisture content air dried
I have cut some boards from a dead maple tree blown down on my property. I bought a moisture meter and the wood is about 12%. I have stacked in my shop and have a fan blowing through. I want to build a desk with the lumber. At what moisture content can I successfully build with the air dried lumber? I have no way to kiln dry it.
5 replies so far
View Monte Pittman's profile
Monte Pittman
30158 posts in 2580 days
#1 posted 04-29-2013 08:47 AM
They always say 7-10%. That said, depending on local humidity that may not be possible.
View WDHLT15's profile
WDHLT15
1797 posts in 2718 days
#2 posted 04-29-2013 11:57 AM
Bring the boards inside your house and sticker stack them in an out of the way place for about 1 month. The wood will come into equilibrium with the environment inside the house.
View bondogaposis's profile
bondogaposis
5157 posts in 2593 days
#3 posted 04-29-2013 01:55 PM
How thick are they? and how long have they been drying? Moisture meters only measure surface moisture. If they are 4” thick slabs that have been drying for only 6 months, that would be asking for trouble.
-- Bondo Gaposis
View mcgyver's profile
mcgyver
56 posts in 2113 days
#4 posted 04-29-2013 02:55 PM
cut about 6 in off end of a board and check center 7-10 % as said before you can place boards in attic stickered it will act as a solar kiln. if it is not dry and u decide to putin attic paint ends for uniform moisture release. dryed chery like this in loisiana 40 -50% humidity dried to 8% moisture center works great
-- Mcgyver
View Seed's profile
Seed
#5 posted 04-29-2013 03:53 PM
I cut the boards to about 1 1/4” hoping to mill them down to 3/4” or so. My shop/garage is not heated, but gets some heat from the house. I stickered the boards and have a fan blowing between them. I have read that it is difficult to get the wood below 10% MC by air drying. The tree had been dead for several years, I’m not sure how long when it blew over.
