Laminating glass and wood in butcherblock
Forum topic by GrandpRas posted 04-28-2013 02:39 AM 999 views 0 times favorited 6 replies Add to Favorites Watch
View GrandpRas's profile
9 posts in 1800 days
04-28-2013 02:39 AM
Topic tags/keywords: laminating glass wood led lighting question
I have a desire to make a table that uses 1 1/2” lumber laminated with 1/2” glass cut in 1 1/2” strips such that the glass panel in parallel to the lumber and the 1/2” width of the glass is seen from the top of the table. I have the tools to drill the glass so that the glass can be bolted between 2 boards and the glue to bond the glass and wood together. What I am wondering if wood expansion and contraction will crack the glass or if the bonding will sufficiently reinforce them safely together. I want to do this so that I can underlight the glass using led lighting. Thoughts?
View Lee Barker's profile
Lee Barker
2170 posts in 2787 days
#1 posted 04-28-2013 03:27 AM
Exciting ideas there. I’d say go for it. If you don’t bolt it together, the wood can do its moving thing as needed.
Either it will work, which is good,
Or it won’t and you’ll get knowledge out of the deal, which is good.
On my wall it says, “Try, Fail, Learn.”
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View swoper's profile
59 posts in 3161 days
#2 posted 04-28-2013 03:43 AM
the glass will dull a cutting edge real quick, if you don’t mind sharpening your knives often I think it will look cool too.
-- Harry, Jackson Mi
View Odiferous's profile
105 posts in 2128 days
#3 posted 04-28-2013 03:51 AM
Sounds like it’d be an interesting look. If the glass edge is clear, I’d would wonder what the glue would look like—it might be a cool effect, or it might look really bad. If you’re thinking of through-bolting it all together anyway, you might just skip on the glue entirely and let the wood show through.
As for expansion, having the grain oriented as if quartersawn ought to keep most of the expansion in the vertical plane instead of adding pressure to the glass.
10116 posts in 3584 days
#4 posted 04-28-2013 04:57 AM
Make some sample “sandwiches” and observe what happens
as the wood moves.
You may consider using rubber shock washers countersunk
into the wood or something like that.
4183 posts in 2346 days
#5 posted 04-28-2013 02:14 PM
I like Loren’s idea, try a sample sandwich and see how it works before investing time and effort for a potential epic fail. The idea sounds cool. Make a sample and post a picture….
#6 posted 04-28-2013 04:26 PM
Thanks all for the comments and ideas. I think the best direction is to mock up a few prototypes – glued and bolted, bolted only, glued only and see what happens. I am looking at using WeldBond or E6000 to maintain as transparent bonding as possible.
