I need help clamping...
Forum topic by Belg1960 posted 04-27-2013 10:14 PM 1153 views 0 times favorited 15 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1068 posts in 3061 days
04-27-2013 10:14 PM
Guys, I’m working on a project which has 60 degree roofs which are about 7” long and 4+/-” wide, they have been pre-finished and I would like to glue them together but my clamps keep sliding off. Its across the 4” peak I want a tight joint.
-- ***Pat*** Rookie woodworker looking for an education!!!
15 replies so far
View TheeWoodShed's profile
TheeWoodShed
165 posts in 1906 days
#1 posted 04-27-2013 10:24 PM
Could you put a couple pin nails in it until the glue dried? I’ve never had a lot of luck with pre-finished pieces holding together with just glue. But could be the glue I use.
-- "Choose a job you love, and you will never have to work a day in your life."
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#2 posted 04-27-2013 10:27 PM
Make a jig and glue them upside down?
TopamaxSurvivor
18268 posts in 3672 days
#3 posted 04-27-2013 10:31 PM
I would do it with wedges in a square box.
View JAAune's profile
JAAune
1798 posts in 2313 days
#4 posted 04-27-2013 10:53 PM
If I understand the problem correctly, this is how I’d resolve it.
The green part represents a piece of plywood with an angled block glued to the top. Two of these get clamped to the birdhouse top then clamps are placed across the angled blocks to close the joint.
Sandpaper is normally what I’d use as the non-slip substance on the piece of plywood that contacts the birdhouse top. On a finished surface you may choose to glue non-slip rubber drawer liner there instead.
Basically the way clamping works, if you can provide surfaces parallel to the joint being glued on either side, you’ll be able to clamp across the joint perfectly.
JAAune
#5 posted 04-27-2013 10:56 PM
- deleted accidental double post -
Belg1960
#6 posted 04-27-2013 11:07 PM
Mark, the pieces were only finished on the “good side” I don’t think the birds will care if there roof is finished on the inside. LOL I used the pin nail method to do the ones in the pics but they are not as tight as I would have liked.
Jaaune, I like this method and I think ill just make it a little longer and glue a block on the bottom as well to stop it from lifting. Thanks for the suggestions, this place rocks.
117090 posts in 3573 days
#7 posted 04-27-2013 11:15 PM
I agree with JAAune’s aproach.
TheeWoodShed
#8 posted 04-27-2013 11:22 PM
Pat, JAAune’s model is perfect! Dang I wish I knew how to use those newfangled software programs!!!! That was sweet and showed you exactly how to do it!!!
Good Luck!!!!
View Lee Barker's profile
Lee Barker
2170 posts in 2846 days
#9 posted 04-28-2013 03:39 AM
There are some creative and practical solutions offered here. And then mine, way less drama and cleverness:
I’d lay these good side up, pointy edges just touching, and tape them together with masking tape.
Turn it upside down, spread the glue (an acid brush is very helpful in this situation) and fold it together. Results are amazing.
Kindly,
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2305 days
#10 posted 04-28-2013 06:54 AM
I agree with Lee and James 101.
Miter folding is easy and effective. Use some good packing tape, not masking or painters tape.
View Tony_S's profile
Tony_S
867 posts in 3079 days
#11 posted 04-28-2013 09:53 AM
Yep, masking tape. Simple and effective.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
Belg1960
#12 posted 04-28-2013 02:07 PM
Thanks again for the suggestion, when I do a more precise project I think this will come in very handy. These pieces were rough sawn and aren’t consistent enough to get great joints.
Lee Barker
#13 posted 04-28-2013 02:53 PM
A little flagrant hijackage here, regarding tape types.
I have used masking tape because it is actually stretchy. If I put a little tension on it as I’m applying it, there’s pull involved.
I’m interested in packaging tape too—would it have other advantages?
Now back to the OP: If the cut’s aren’t so good, two other adhesive choices would be epoxy and polyurethane.
Kindly,
View Wdwerker's profile
Wdwerker
333 posts in 2229 days
#14 posted 04-28-2013 03:07 PM
They sell a clamping aid called “Blockz”. I think Lee Valley/Veritas sells them now. Comes with rubber liners for not marking finished pieces.
I would use a domino , biscuit or dowel to strengthen the joint.
-- Fine Custom Woodwork since 1978
View jap's profile
jap
1251 posts in 2050 days
#15 posted 04-28-2013 05:44 PM
I would use masking tape or packing tape.
-- Joel
