Look at this Wood Pile, What are my options?
Forum topic by jordanp posted 04-27-2013 07:59 PM 1914 views 0 times favorited 25 replies Add to Favorites Watch
View jordanp's profile
1086 posts in 1874 days
04-27-2013 07:59 PM
Topic tags/keywords: wood tree lumber milling
This is sitting across the street I don’t have any milling equipment, I do have a table saw and access to a medium sized Bandsaw
I’ve never milled wood for lumber what options to i have any thoughts or suggestions?
I would really like to make use of this pile before someone grabs it.
Also I think it is Cotton wood tree I’m in North Texas can anyone confirm the species?
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
25 replies so far
View Dallas's profile
3599 posts in 2421 days
#1 posted 04-27-2013 08:04 PM
I could guess what kind of wood, but closer pictures would be a lot better.
And Alaskan chainsaw mill is @ $200 and you could make a lot of slabs with that wood.
View NormG's profile
5900 posts in 2938 days
#2 posted 04-27-2013 08:07 PM
Cry and/or invest in a mill of some sort
-- Norman - I never never make a mistake, I just change the design.
#3 posted 04-30-2013 09:01 PM
I found out it is a Hackberry Tree
View Mip's profile
453 posts in 2012 days
#4 posted 04-30-2013 09:17 PM
Hire a sawyer to come over to slab it up. Shouldn’t be that expensive. I would ask the homeowner first if it’s okay to grab it.
View Brandon's profile
4152 posts in 2885 days
#5 posted 04-30-2013 09:18 PM
Do you have a chainsaw? You can get it into rough square shapes with the chainsaw and then run it through the bandsaw.
-- "hold fast to that which is good"
View kdc68's profile
2644 posts in 2211 days
#6 posted 04-30-2013 09:39 PM
Great idea Brandon W....
-- Measure "at least" twice and cut once
View Loren's profile
10101 posts in 3582 days
#7 posted 04-30-2013 09:53 PM
You can also split it from the sides, in halves then in quarters.
Once it is quartered it won’t check so easily.
This is the old way of doing it, using a metal wedge to start
the split and big wooden wedges to open the logs up the
rest of the way.
Don’t chainsaw it without a full face shield. Fungus loves the
moisture and you may have an allergic reaction if it gets in
your mucus membranes.
117032 posts in 3511 days
#8 posted 04-30-2013 10:00 PM
you could make some log furniture.
-- wood crafting & classes
View bobasaurus's profile
3393 posts in 3118 days
#9 posted 04-30-2013 10:18 PM
I would take a few of the smaller logs, seal the ends, and put them aside until you find a way to mill or split them. I often split logs down the center and use each half to make bowls on the lathe.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View wiswood2's profile
1138 posts in 3630 days
#10 posted 04-30-2013 11:35 PM
I would get it to your house and then you would have time to figure out what you want to do with it, other wise some one else will get it before you.
-- Chuck, wiswood2
View stefang's profile
15878 posts in 3268 days
#11 posted 05-01-2013 06:16 PM
I think Loren has the best idea. I have done this myself a lot and it is a lot easier than many think. The problem with sawing urban trees is that they are likely to have nails in them from kids messing around. This will ruin blades. If you split them, you will likely find any imbedded foreign objects prior to sawing. Also as Loren says, getting quartered gives you some really great stable wood to work with. Just remember that you will have to slab it, sticker it and let it dry for about 1 year per inch of thickness. I would cut it thick enough to allow for planing later.
View Straightbowed's profile
717 posts in 2232 days
#12 posted 05-01-2013 06:40 PM
you can use a chainsaw and some heavy sawhorses and a strong back and slab that up let it dry then mill it with a good band saw try to make the slabs 2 3/4 inches so you can run them in thr tablesaw thats what i done to a bunch of walnut take the sawhorses make a good heavy table and saw them or haul them out to a guy with a woodmizer shouldn’t cost to much to slab it or just saw it up
-- Stevo, work in tha city woodshop in the country
View redSLED's profile
790 posts in 1826 days
#13 posted 05-02-2013 03:03 AM
For the love of God, I hope you IMMEDIATELY grabbed the biggest chunks right away and put them in your shop/garage, so you could figure out everything later.
View Woodknack's profile
11311 posts in 2314 days
#14 posted 05-02-2013 04:00 AM
I would only take trunk pieces as I’ve never had good luck with limbs. Seal the ends and split or resaw them within a week or they’ll check like crazy.
-- Rick M,
View crank49's profile
4030 posts in 2905 days
#15 posted 05-02-2013 04:19 AM
Hackberry is a pretty sappy wood.
Expect it will check a lot.
