A Sharpening Quandary
« back to Hand Tools forum
Forum topic by TheWoodenOyster posted 04-27-2013 03:11 PM 1408 views 0 times favorited 20 replies Add to Favorites Watch
TheWoodenOyster
1311 posts in 1809 days
04-27-2013 03:11 PM
I am having some trouble getting the “mirror polish” on the back side of my tools during my sharpening sessions. I don’t think it is my form or anything like that, because though I do lack skill in lots of woodworking categories, I can actually sharpen pretty well. I have been working on a set of chisels that my parents got me for my birthday. I go through 100, 150, and 220 glued to a granite slab. Then I go through 325 and 1200 on my diamond stone. Then I go to my 4000 and 8000 water stones. Things go well until I have been at the 8000 stone for about 30 minutes and I am making no progress. I am a pretty patient and persistent person, but it seems like I come to a screeching halt somewhere between 4000 and 8000. I can see the scratch marks from to 4000 stone disappear, and I start to get a “mirrorish” finish, but it stays a hazy color instead of clearing up to the perfect mirror finish I have seen guys attain. The blade is still very sharp, but I guess it is just the perfectionist in me that wants to get to the perfect mirror finish. It makes me wonder what the heck I bought this $100 8000 grit stone for. Anybody have any idea why this would be happening?
Thanks
-- The Wood Is Your Oyster
20 replies so far
View rhett's profile
rhett
742 posts in 3541 days
#1 posted 04-27-2013 03:31 PM
You need a leather strop.
-- Doubt kills more dreams than failure.
View redSLED's profile
redSLED
790 posts in 1767 days
#2 posted 04-27-2013 03:39 PM
I envy your available time in trying to achieve a mirror finish. Good topic title.
View MrRon's profile
MrRon
4566 posts in 3118 days
#3 posted 04-27-2013 03:40 PM
My guess would be the steel in the tool.. Try some other tool and see if it makes a difference. I finish my tools on a polishing wheel with rouge.
Smitty_Cabinetshop
14960 posts in 2493 days
#4 posted 04-27-2013 04:25 PM
Strop is the answer. See Paul Sellers’ video on the subject; 30 strokes on a charged strop… You’re almost there!
View HorizontalMike's profile (online now)
HorizontalMike
7727 posts in 2788 days
#5 posted 04-27-2013 04:54 PM
I am with Ron on the use of a buffing wheel for honing. That said, I had been doing the traditional scary sharp method on all my chisels and HPs, UNTIL I got into turning and converted a $79 HF 4×36 belt sander into a sharpening station. For me that was a game changer. Not only could I sharpen all of my turning tools, but all others as well. This belt sharpening system can use grits from 36g to as high as 600g, and the buffing wheel with “green” polish (~10,000g I think) is just icing on the cake. All said and done, I have maybe $110 in the thing.
Something to consider…
Harbor Freight 4x36 Belt Sander DIY CONVERSION To Belt Sharpening System
TheWoodenOyster
#6 posted 04-27-2013 05:13 PM
Awesome replies everyone. I have been out in the garage working on it more and I apparently was summoning you all because I had the idea to skip the 8000 stone and just hit it with my strop (which I saw on Paul Sellers video- good call smitty). It did put the mirror finish on it, but I am a little worried that at the very end of my chisels, there is going to be a very slight bow upwards because of the leather on my strop deflecting down as I push the back of my chisel down onto it. I think I can live with that though. I am starting to split thousandths and I think I need to just get to work on my projects. No doubt more skill and epiphanies will come with time.
Some other comments:
Mr Ron- the tools steel that I have encountered this problem with is all Stanley tool steel – you might be onto something there
Horizontal Mike- That converted belt sander idea is pretty tempting. That might be something to try out once I get addicted to turning, which is only a matter of time
Thanks again for the responses. Isn’t it just a wonderful thing how all the problems we have to solve make us stretch our minds and creativity to its limits. Awesome!!!
116813 posts in 3451 days
#7 posted 04-27-2013 05:28 PM
I sharpen on a “Work sharp” that uses sand paper. I go through all the grits starting at 120(depending on the condition of the chisel) without skipping any of the grits in between up to 1200 and then 2000 I always get a Mirror finish. I have a leather wheel but I have a mirror finish before I use it.
View bandit571's profile
bandit571
18927 posts in 2557 days
#8 posted 04-27-2013 05:49 PM
Very simple set up in my shop
The two power tools i use. Grinder for those really bad edges first. The belt sander is used with a honing guide to get rid of the grinder marks
Then the vise can hold the oil stones i use
After both faces of the stones, I wrap some sandpaper around the stone, as tight as i can. Using both 1000 grit and 2000 grit paper, with a dab of 3in1 oil. Does all this work?
I recently picked up a piece of tile, and have been trying it out as a stone. Leather strop? MIGHT have something i could use in this old thing
There is a nice wide leather belt in there, somewhere….
View waho6o9's profile
waho6o9
8070 posts in 2451 days
#9 posted 04-27-2013 06:02 PM
A nagura stone is recommended for use on stones 8000 grit and higher.
It produces a slurry and achieves the mirror look you want.
YMMV
View Mark Kornell's profile
Mark Kornell
1169 posts in 2405 days
#10 posted 04-27-2013 06:38 PM
Is your 8000 stone dead flat?
-- Mark Kornell, Kornell Wood Design
TheWoodenOyster
#11 posted 04-27-2013 07:36 PM
I wasn’t aware that was what the nagura stone is for… I’ll give that a whirl
Yes it is flat. I flatten it on a granite slab after every use
View crank49's profile
crank49
4028 posts in 2845 days
#12 posted 04-27-2013 08:18 PM
I don’t spend 30 minutes on all grits combined. What are you sharpening, Carbide?
View Paul C.'s profile
Paul C.
154 posts in 3119 days
#13 posted 04-27-2013 08:34 PM
Bear in mind many of us do not have a mirror polish on the backs of our tools, and we still get them very very sharp. For some of my tools, I doubt that would be attainable anyways. That said, a leather strop will give you that little extra for sharpening. its great for refreshing an edge as well.
View Dallas's profile
Dallas
3599 posts in 2361 days
#14 posted 04-28-2013 12:19 AM
Isn’t a quandary a cross between the place they dig up rocks and gravel and the place they pour metal into forms for tools?
View DavidNJ's profile
DavidNJ
389 posts in 1868 days
#15 posted 04-28-2013 01:47 AM
Not all 8000 stones are the same. In the Lee Valley catalogue there is a chart that compares several.
I use lapping paper finishing off with 0.1μ or 0.3μ. As the chart shows, some 8000 grit stones are as big as 3.0μ
