White glue fiasco
Forum topic by RussellAP posted 04-27-2013 02:32 PM 1135 views 0 times favorited 10 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2190 days
04-27-2013 02:32 PM
I do inlays of powder and crushed stones. I’ve been using CA glue but it discolors the wood and there is really no way to be neat with the thin CA. Nothing protects a curved surface from it’s effects and you have to sand the shape out of things to remove the discoloration.
I spoke to Charles Neil about this and he suggested white glue. So I came here asking you guys what white glue is and if there is some special brand to get.
The consensus was plain old Elmers white glue.
I tried it in a hole in some walnut. Not a big hole, but at least 1/2” x 1/2” with some minor cracks.
I mixed the glue with the copper powder and troweled it in.
I waited 24 hours. Started to sand, but the glue was still wet inside. The heat from the sanding made it rise like a blister.
So I waited another 48 hours. Already I’m thinking this takes way too long for me.
Still not dry. And sanding it produces some kind of mess that you end up having to cut off.
So relying on the strength of Charles and his advise, I must be an idiot to have messed this up so bad.
I’d really like to hear from anyone who has done this and if you could tell me where I’ve gone wrong.
10 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2481 days
#1 posted 04-27-2013 03:49 PM
Epoxy.
View Hammerthumb's profile
Hammerthumb
2818 posts in 1879 days
#2 posted 04-27-2013 04:11 PM
1/2×1/2 is pretty large space to fill. It will take a long time for the glue to dry for a fill that large. Nite is right, epoxy for that large an area.
-- Paul, Las Vegas
RussellAP
#3 posted 04-27-2013 04:12 PM
Well then why not use epoxy for everything. Does it go into the wood?
View Jimbo4's profile
Jimbo4
1600 posts in 2667 days
#4 posted 04-28-2013 01:35 AM
Russell – I’ve had good luck using CA on small areas, as long as I seal the edges with shellac, or Deft sealant. On items larger than 1/4 inch, I use epoxy mixed with whatever I’m going to use as a filler, i.e., brass key shavings, turquoise, etc. As long as the area to be filled is undercut, it should be alright. I haven’t had any problems doing it this way. When using epoxy, and a colorant is used (dye, etc), the edges should be sealed as with the CA. The epoxy will absorb in to the wood, as long as there is no sealant in the area to be filled.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
NiteWalker
#5 posted 04-28-2013 01:44 AM
You could use epoxy for everything; the main reason not to is cost.
View Mark's profile
Mark
84 posts in 1864 days
#6 posted 04-28-2013 02:17 AM
I spray the area with a clear lacquer or acrylic and use thick or med. CA. spray with accelerator.
-- Mark clio,mi ..making wood talk is fun
View Jim Finn's profile
Jim Finn
2618 posts in 2826 days
#7 posted 04-28-2013 08:17 PM
I use a lot of white glue /sanding powder mix to fill SMALL voids and it works well. Also I have mixed shellac with sanding powder to fill small voids. I use epoxy on larger (deeper) voids.
View MarkwithaK's profile
MarkwithaK
370 posts in 3082 days
#8 posted 04-28-2013 08:24 PM
As mentioned above, a 1/2” X 1/2” seems like an awful lot. Have you, or can you, try a shallower hole?
-- If at first you don't succeed then maybe skydiving isn't for you.
RussellAP
#9 posted 04-28-2013 11:19 PM
James101 I’ve tried that. didn’t seem to be clear enough. I mixed the copper dust in the one clear stuff then mixed the other stuff in. Maybe I’ll try it after its mixed then add the copper dust.
View crank49's profile
crank49
4029 posts in 2875 days
#10 posted 04-29-2013 01:42 AM
Maybe you could fill the cavity about 90% full with filler made from sandinf dust and shellac. When this si dry then fill the top 10% with your brass/bronze epoxy mix.
