How do you thin GF oil base poly?
Forum topic by RussellAP posted 04-27-2013 12:37 AM 729 views 0 times favorited 4 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2284 days
04-27-2013 12:37 AM
I left the can open last night. It looks like the same consistency, but I should thin it a little.
I have mineral spirits, denatured alcohol, and some mineral oil.
What should I use?
View PittsburghTim's profile
PittsburghTim
230 posts in 2319 days
#1 posted 04-27-2013 12:47 AM
Russel, are you using Arm-R-Seal or one of their floor poly’s?
-- She asked me, "Who are you going to please with that?" I said, "Me."
RussellAP
#2 posted 04-27-2013 12:49 AM
Arm-R-Seal
PittsburghTim
#3 posted 04-27-2013 12:54 AM
Russel, I would use mineral spirits. I used them to thin down the first several coats on the walnut coffee tables in my projects section. This was necessary to “fill” the porous grain of the walnut and avoid tiny air bubbles that would form when used full strength. I followed up with several coats of it straight from the can and had no problems whatsoever.
Good luck with your project,
Tim
RussellAP
#4 posted 04-27-2013 12:57 AM
Thanks Tim. I need a new can, but I’d like a thinner can for some final top coat. Needs to be very thin like shellac and mineral oil. I just keep coating them and sanding with some very old 600g till they sparkle.
