sanding plywood turnings
« back to Woodturning forum
Forum topic by wiser1934 posted 04-26-2013 02:53 AM 896 views 0 times favorited 5 replies Add to Favorites Watch
View wiser1934's profile
wiser1934
524 posts in 3146 days
04-26-2013 02:53 AM
Topic tags/keywords: sanding turning plywood
any feedback on sanding plywood turnings. i used some baltic birch plywood on some salt and pepper shakers. seems to require extra sanding thanks
-- wiser1934, new york
5 replies so far
View Wildwood's profile
Wildwood
2306 posts in 2134 days
#1 posted 04-26-2013 11:08 AM
Hard to answer your question without seeing a picture.
-- Bill
View Lee Barker's profile
Lee Barker
2170 posts in 2850 days
#2 posted 04-26-2013 02:01 PM
Sand as needed!
Kindly,
View Bob Collins's profile
Bob Collins
2514 posts in 3683 days
#3 posted 07-19-2013 08:37 AM
I recent purchased some ABRANET SANDING SHEETS from www.rubberchucky.com and found it ideal for hand sanding plywood turnings. Sheets come in 80,120,180,240,320,400, 600 grit, and found that working through the grits leaves an excellent finish. Also works well with the lathe at low speed.
-- Bob C, Australia. Your best teacher is your last mistake.
View TheDane's profile
TheDane
5423 posts in 3662 days
#4 posted 07-19-2013 03:15 PM
Bob Collins makes a good point … Abranet sanding materials are first rate. Our local AAW club buys Abranet in bulk, we cut it into sheets, and sell to members at deeply discounted prices.
I would suggest using a sanding sealer (shellac or lacquer). I would rough sand (80 grit), apply a generous coat of sealer, then start going through the grits.
wiser1934
#5 posted 07-21-2013 03:25 AM
thank you for your input re plywood turnings. i will try abranet. have some i bought long time ago and forgot about. thanks again to both
