Chip out on chamfers
« back to Hand Tools forum
Forum topic by hiswillus posted 04-25-2013 07:31 PM 777 views 0 times favorited 7 replies Add to Favorites Watch
View hiswillus's profile
hiswillus
70 posts in 1914 days
04-25-2013 07:31 PM
Can’t seem to not get chip out when chamfering to a corner. Even when using a plane to make a light chamfer to avoid any chip out when planning end grain. Any and all tips would be greatly appreciated!
Thanks,
Jeff
7 replies so far
View Mark Davisson's profile
Mark Davisson
597 posts in 3282 days
#1 posted 04-25-2013 07:39 PM
The first thing I would try would be to clamp a board to the trailing surface as a backer.
-- I'm selfless because it feels so good!
View widdle's profile
widdle
2069 posts in 2964 days
#2 posted 04-25-2013 08:23 PM
Yoo could try coming in from each corner…
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2038 days
#3 posted 04-25-2013 09:42 PM
push into the corner, and only push through half way. then come back out it from the opposite corner. Once one face is done, you can start at any undone corner and push all the way across. As long as the material is removed at the opposite corner it should no “tear out”
Same as what Widdle is suggesting, just a little more specific??
-- Who is John Galt?
View jap's profile
jap
1251 posts in 2019 days
#4 posted 04-25-2013 09:52 PM
try steeply skewing the plane when you go accross.
-- Joel
View Loren's profile
10261 posts in 3613 days
#5 posted 04-25-2013 11:12 PM
Skewing the plane can help. Skewing reduces the effective
cutting angle. You can also skew the block plane about
45 degrees so the front of the plane is heading towards
the ceiling, slide it across to make the cut and then at the
end push it upwards to finish the cut.
You can also just nick the ends before you plane with
a chisel or file. You can cut a little triangular flat on
each corner (mark it out with a gauge if you like),
then plane the chamfers until the flats disappear
and become the chamfer corners.
View Don W's profile
Don W
18685 posts in 2533 days
#6 posted 04-26-2013 12:09 AM
I come in from each corner to avoid it.
hiswillus
#7 posted 04-26-2013 07:53 AM
Thanks guys, for all the support!
