Running a PM1300TX-CK with 110v
Forum topic by TomB19 posted 04-24-2013 02:59 PM 1200 views 0 times favorited 9 replies Add to Favorites Watch
View TomB19's profile
51 posts in 1903 days
04-24-2013 02:59 PM
I picked up a Powermatic PM1300TX-CK a few weeks ago and I’ve come to discover it will not run on a 110v/15A circuit. Powermatic recommends 30A if run on 110v.
If I had 30A, I should be able to drive a 3hp extractor.
Has anyone successfully run this extractor on 110v/20A? My shop is wired with 12Ga wire so 20A would be relatively easy.
My table saw is 3hp and it is happy to run on 220v/15A. If I had known I would require another 220v circuit in the shop, I would have gone for a larger extractor.
I’m also considering going with a smaller impeller as a temporary work-around.
9 replies so far
View Milo's profile
869 posts in 3254 days
#1 posted 04-24-2013 03:06 PM
Hmm. Tom, I’ve been studying electrical issues lately. It’s not TOO hard (or terribly expensive) to put 30amp breaker in and run a line. What is your shop set up? How far is your extractor from the fuse box? How hard would it be to run wire and install a new recepticle?
I know I’d want to go with the manufacturers specificiations if I could.
Good luck!
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View Cosmicsniper's profile
2202 posts in 3093 days
#2 posted 04-24-2013 03:06 PM
Isn’t the PM1300 less than 2hp? If so, there should be zero issue with running on a 20a circuit. Since you already have 12ga wire, just put in a 20a breaker. It will need to be on its own circuit, however.
-- jay,
View scotsman9's profile
134 posts in 1823 days
#3 posted 04-24-2013 03:07 PM
Why are you trying to circumvent using a 30A breaker?
12AWG CU is allowed for 30 amps if it’s Type TBS, SA, SIS, FEP, FEPB, MI, RHH, RHW-2, THHN, THHW, THW-2, THWN-2, USE-2, XHH, XHHW, XHHW-2, or ZW-2
You should be fine.
-- Just a man and his opinion.
#4 posted 04-24-2013 04:38 PM
Thanks for the comments.
I don’t know if I can run 30A on 12Ga in my area. I’m not an electrician so I need to do everything by the book because they scrutinize homeowner permits pretty close. The run length is about 30’.
The point here is that if I had spare of positions, I’d have gone with a 220v solution. The panel is full so this is going to be expensive.
View PurpLev's profile
8534 posts in 3583 days
#5 posted 04-24-2013 04:49 PM
just put it on it’s own 20A circuit- change one of the 15A to 20A breaker – BUT , make sure your area permits doing so on a 12 gauge wires.
1 3/4HP motor should run OK on 20amp
View Loren's profile
10106 posts in 3582 days
#6 posted 04-24-2013 04:57 PM
Do you know about duplex breakers? That’s what I use.
Two 20 amp duplex breakers can run 2 220v lines, 1 220v
line and 2 110v lines, or 4 110v lines.
#7 posted 04-24-2013 07:38 PM
Thanks, Loren. Somebody has replaced every 15A single position breaker with a duplex breaker.
My electrical system needs upgrading. It’s just a matter of finding a spare several thousand. lol!
I’m going to try to run it on a 110v/20A. If that doesn’t work, I’ll swap a smaller impeller.
Thanks for the help. :)
View toolie's profile
2117 posts in 2563 days
#8 posted 04-24-2013 08:37 PM
or buy a book about electrical wiring and install a sub panel as i did. if the main panel has a single main breaker, once the main breaker is de-energized, it’s kind of hard to get hurt inside the panel until the main breaker is re-energized. adding a 60-100A subpanel shouldn’t be more than a thousand, on the high side. parts would amount to ~ $200.
-- there's a solution to every just have to be willing to find it.
#9 posted 05-05-2013 08:59 PM
OK. I had an electrician in to upgrade my wiring. First, he installed a 20A circuit. That didn’t work. It came up to speed about 1 time out of 4 and then only if the intake was choked right off. It’s now on a 110V/30A circuit and working fine, so far.
I thought a shop vac was fine, and I still do, but a shop vac simply isn’t up to some of the larger jobs. The Powermatic is a monster. I’ve been in other shops that have a 1.5hp collector and they don’t seem anything like this one. Either this collector is under-rated or the cheap clone collectors are over rated. The PM1300TX-CK can have a couple of four inch gates open and still have plenty of power to run a floor sweep.
Here’s something you’re never going to hear anyone else say. If I was doing it again, I would have a harbor freight collector with the 13” wok mod. It would provide all the dust collection I need. This Powermatic unit is overkill. I’d be scared to turn this one on with my dog in the shop for fear it would suck him into the vortex. lol!
Perhaps I will grow to appreciate the capacity in time. I’m certainly not knocking the capability of this unit. I just doubt I need it.
Dislcaimer: I do lots of construction carpentry and don’t worry about dust, with the exception of trying to keep interior finishes clean. I’ve had a workshop for decades and have never had a dust collector connected to a table saw before. As long as I don’t work with MDF, I don’t mind a small amount of dust in the air. If I were completely honest, the main reason I went for the collector is so I don’t have to shovel out the table saw on a regular basis.
