Delta 22-540 planer problem
Forum topic by Andrew Betschman posted 04-24-2013 02:26 PM 995 views 0 times favorited 2 replies Add to Favorites Watch
View Andrew Betschman's profile
Andrew Betschman
309 posts in 3250 days
04-24-2013 02:26 PM
my planer is out by .020’ side to side. On the left i got a reading of .947” on the right is at .927” What adjustment can i make to get is back? The blades are sharpen straight, and set in the cutter head parallel.
-- Andrew, Ohio https://www.etsy.com/shop/AndrewBetschman
2 replies so far
4999 posts in 2520 days
#1 posted 04-24-2013 06:50 PM
I sold mine over 10 years ago, so I’m going on memory. I don’t believe there is an easy way to adjust the cutterhead, if you’re absolutely sure that’s what’s off. You may have to adjust one of the 2 screws the assembly rides on, and I’d bet that getting it turned to adjust by .02” is going to be tough. It would amount to turning one screw enough to correct, then repositioning the drive belt (or chain, can’t remember) cog and getting it back in sync.
View Moron's profile
Moron
5032 posts in 3920 days
#2 posted 04-25-2013 01:52 AM
whoa
nothing a little sanding cant fix
