Maintaining Equipment
Forum topic by WayneE posted 54 days ago 254 views 0 times favorited 18 replies Add to Favorites
View WayneE's profile
WayneE
5 posts in 56 days
54 days ago
Topic tags/keywords: tablesaw jointer
Can anyone suggest a product that I can use on my jointer and table saw to protect them from rusting?
Wayne
View motthunter's profile
motthunter
1234 posts in 335 days
54 days ago
empire makes a good product.. but johnsons paste wax can work well too.
-- making sawdust....
View SCOTSMAN's profile
SCOTSMAN
539 posts in 122 days
54 days ago
Yes the wax paste is very good helps things slide too if it’s the same one I am thinking of.regards Alistair
WayneE
5 posts in 56 days
54 days ago
Thank you for the information.
Wayne
View Huckleberry's profile
Huckleberry
73 posts in 389 days
54 days ago
Renaissance wax is good for a smooth sliding surface how well it will prevent rust I don’t know, also it is a little on the pricey side.
-- Something that goes unnoticed will never be remembered.
View Loren's profile
248 posts in 184 days
54 days ago
I’ve used paste wax mostly. There are other more costly lubricants
that work well too. I bought some machine covers that are some
sort of breathable, waterproof cotton. They help keep the airborne
water off in the first place.
No method is perfect. Rust happens. Keep a brass wire brush handy
and you can whisk it off pretty quick, apply some fresh wax, and you
are good to go.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
View cmaeda's profile
cmaeda
99 posts in 91 days
54 days ago
I also use paste wax. I don’t bother with Renaissance, I just use Johnsons.
One more thing I do is spray primer on the underside of my table saw table. (Take off the top, don’;t spray it while its’ assembled.)
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
54 days ago
I use paste wax.
Johnsons, Trewax, Butchers… Whatever the local store has.
-- - Real men read directions
View Hrolfr's profile
Hrolfr
99 posts in 202 days
54 days ago
I use the kit listed here http://www.woodcraft.com/family.aspx?FamilyId=984
-- Hrolfr
View Southern_Woodworker's profile
Southern_Woodworker
6 posts in 58 days
54 days ago
I have used both T9 Boeshield and TopCote of which both are great products. Recently I have become more partial to the boeshield product because it seems that it lasts a little longer than TopCote and I get a few more treatments per can. However the Boeshield is slightly more expensive. If you have rust on the top the T9 Rust Free is also a great product.
I also use the Renaissance wax and don’t have any complaints with it. I primarily use it for my hand tools because they require very little and the spray products are a little faster on the larger tools. The main thing is to stay away from the Silicone products so you don’t have problems in the finishing stages later on.
View Sawdustonmyshoulder's profile
Sawdustonmyshoulder
104 posts in 165 days
54 days ago
Top-Cote… I live in hot, humid, rainy northern Mississippi. No rust, no drips, no errors!
Note that I have not used T9. I have only used Top-Cote. Hope this helps.
-- Makin' Sawdust!!!
View bbqking's profile
bbqking
277 posts in 260 days
53 days ago
Regular, old Turtle Wax. Used it for years. No rust. I bought Boeshield and it is good for removing rust, with a little elbow grease, but nothing prevents rust better than a nice coat of wax, properly maintained. Cheap, too.
-- bbqKing, Lawrenceville
View Chris 's profile
Chris
1259 posts in 528 days
53 days ago
Paste Wax here as well; Have not bothered to try anything else.
-- Chris
View John Ormsby's profile
John Ormsby
194 posts in 273 days
53 days ago
I use talcum powder on my surfaces. They look as new. Just wipe on thinned kerosene if you are storing in a garage. Kerosene repels water. Throw old bed sheets over the equipment when not in use. It works well.
-- Oldworld, Fair Oaks, Ca
6716 posts in 388 days
53 days ago
Wayne, if you search the LJ site you will find this topic at least twice as far as I know.
View Damian Penney's profile
Damian Penney
729 posts in 528 days
53 days ago
I use Top-Cote, seems to do the trick.
BeechPilotBarry
53 days ago
Actually… Sawdustonmyshoulder brings up a GREAT point!
What works for most of us is region dependent. I live in Connecticut, with “medium” seasons, no salt air, rare high-humidity, and my stuff is in a mildy heated shop. My shop ranges from 55F to 90F through the seasons.
While paste wax works great for me, it may do little for someone in humid Shreveport or Orlando, or an unheated shop that does from 10F to 65F in the same day. In a climate controlled shop or the desert, Boesheild might be a complete waste of money.
View brianinpa's profile
brianinpa
941 posts in 260 days
53 days ago
WD-40 and a rag works for me.
Chris
53 days ago
I am in Florida myself, what I have found is that if I clean my equipment after use then apply the paste wax i have no issues at all. However, If I work on the table saw and just leave a piece of rough lumber on it i will have one heck of a rust spot in no time flat. In the very humid southern US it just requires a little bit more attention.
-- Chris
Bookmark And Share This Page
