Powermatic 90
Forum topic by Jim posted 04-24-2013 08:42 AM 2313 views 0 times favorited 9 replies Add to Favorites Watch
View Jim's profile
14 posts in 1789 days
04-24-2013 08:42 AM
Topic tags/keywords: powermatic 90 oneway turning
I am brand new to woodturning and I recently purchased a Powermatic 90 off of Craigslist. The guy I bought it off of didn’t know much about this lathe. I am trying to figure out how to install a Oneway chuck. I can’t figure out how to get off the drive center. I’m not even sure if that is the correct name for it! I have a lot of learning to do. Any help n this subject would be very much appreciated. Thanks!
-- Jim
9 replies so far
View dlong0's profile
18 posts in 1815 days
#1 posted 04-24-2013 09:26 AM
You will need to have a long dowel(12”) or something like that(they are called knockout bars). The spindle shaft(what the drive spur is held in) is hollow all the way through the headstock. Put the dowel(knockout bar) in the hole on the other side and gently tap it with a mallet or hammer. The drive spur will come right out then.
-- dlong0
View Jim's profile
#2 posted 04-24-2013 02:49 PM
Thanks so much! I thought that was the way to do it but i started that and made a few taps and nothing. So, I thought i better make sure before I break anything. I will get the parts and make a breakout bar this week :-)
-- Jim
View WhoMe's profile
1564 posts in 3174 days
#3 posted 04-24-2013 03:09 PM
If it is stuck bad, you might want to put something on /around/below that live center to catch it when it finally comes lose.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View Loren's profile
10081 posts in 3578 days
#4 posted 04-24-2013 04:47 PM
I use a metal rod. I have not found wood dowels to be
adequate to the task. Sometimes the bar needs a real
solid whack with a hammer, not a mallet.
View Kreegan's profile
1452 posts in 2077 days
#5 posted 04-24-2013 05:52 PM
Make sure to put your hand around the center to catch it when it pops out. Otherwise the point could get smushed like mine did. Some 3/8” all thread should work for a knockout bar.
View Jim's profile
#6 posted 04-25-2013 03:33 PM
That’s a great point, thanks!
-- Jim
View Jim's profile
#7 posted 04-28-2013 08:38 AM
That worked great ! Got it off with a 3/8” rod and a few wacks with a hammer :-)
Now, my next dilemma is what do I need to mount my Oneway Stronghold chuck to the Powermatic? I assume I need an adaptor shaft of some sort? Where do I get one?
Thanks for any help on his matter.
-- Jim
View Wildwood's profile
2267 posts in 2065 days
#8 posted 04-28-2013 11:27 AM
Might check with Craft Supplies or Packard Woodworks for a threaded adapter for your chuck & lathe both sell OneWay chucks. Both vendors very helpful and have free catalogs too!
-- Bill
View Jim's profile
#9 posted 05-04-2013 02:48 PM
Thanks! I will check them out.
-- Jim
