Attaching table legs to aprons.
« back to Joinery forum
Forum topic by lateralus819 posted 04-24-2013 01:13 AM 2081 views 0 times favorited 6 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1791 days
04-24-2013 01:13 AM
I know the popular joint is mortise and tenon. My question is for this project and future, how to determine the length of a tenon and width?
My legs are 3”x3”. The aprons are 3/4”x 3.5” wide.
How far should the tenon go into the mortise? How wide should the tenon be? Can it be full width? cutting a mortise from the top of the leg down 3.5” ?
Thanks.
View ChuckV's profile
ChuckV
3090 posts in 3429 days
#1 posted 04-24-2013 01:47 AM
I would make the tenons about 1/3 the thickness of the aprons, so 1/4”. I would make them 3” wide and centered on the 3.5” aprons.
The legs are pretty hefty at 3” X 3”. Not knowing what kind of weight we are talking about, I would guess that putting the tenons into 3/4” or 1” deep mortises should be fine. You certainly have enough room in the legs to go deeper if you feel that it is needed.
This is just my take on it. I hope that you get some additional ideas from others.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
lateralus819
#2 posted 04-24-2013 01:51 AM
Thank you chuck, The top is 8/4 sapele. So i didn’t want to go to “wimpy” on the legs, both strength and aesthetics. Not to mention, they will have a taper, so that will help as well i think.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3060 days
#3 posted 04-24-2013 01:52 AM
Sliding dovetails. That is all.
-- jay, www.allaboutastro.com
View Rick_M's profile
Rick_M
11077 posts in 2282 days
#4 posted 04-24-2013 02:18 AM
Depthwise I go at least halfway, sometimes 2/3, so on a 3” leg I’d be between 1.5”-2” long tenons. Often I will cut the mortises until they intersect and then angle the ends of the tenons. I was taught to make the tenon half the thickness of the stock but apparently most people do 1/3. I have no rule of thumb for width but generally leave 1/2”+ on each shoulder. So my tenons would be roughly 2×2.5×3/8.
-- http://thewoodknack.blogspot.com/
View bandit571's profile
bandit571
19150 posts in 2585 days
#5 posted 04-24-2013 03:48 AM
One other item can be used, along with the tenons.
Tenons used here are 1/3 the depth of the leg=1/2”. The corner blocks reinforce the corner, and add a way to attach the top.
Some old Mersman legs I salvaged had no tenons in use
as they used a bolt into the inside corner of the leg, a metal plate that was secured with a nut to the leg. Ends of the plates had a lip. It went into slots in the aprons, and also had two screws per apron to hold the joint shut. Worked as long as everything was tightened down….
runswithscissors
2641 posts in 1927 days
#6 posted 04-24-2013 04:20 AM
Rockler, I believe, has those corner plates. I have made my own by cutting, bending, and welding 1 1/2” channel steel. Since I didn’t put lips on them to go into slots in the apron, I simply fastened the ends with screws into the apron. You use a hanger bolt (lag screw thread on one end, machine screw thread on the other), and tighten them down with a nut. Be careful, though, as a nut being tightened has a lot of force, and you can pull the hanger bolt right out of the leg.
