Alternate use for inlay kit
Forum topic by PittsburghTim posted 04-24-2013 12:53 AM 900 views 0 times favorited 1 reply Add to Favorites Watch
View PittsburghTim's profile
PittsburghTim
230 posts in 2291 days
04-24-2013 12:53 AM
Topic tags/keywords: router inlay vise
I am in the process of installing a leg vise on my workbench and it came time to install the brass garter on the chop. Rather than surface mount it, I wanted to mount it flush so I had to create a round, recessed area. I decided to try the Freud inlay setup I have used in the past to inlay bowties in tabletops, only in reverse from how I normally use it.
I screwed the garter to a 1/4 inch thick piece of MDF. I then used the plunge router with the brass spacer installed over the collar and followed the edge of the garter to cut a perfect circle in the MDF. I then removed the brass spacer, clamped the MDF over the chop and routed the chop. The result was a perfect match.
Maybe this use is obvious to others, but thought it may be of use to some of you.
-- She asked me, "Who are you going to please with that?" I said, "Me."
1 reply so far
View waho6o9's profile
waho6o9
8168 posts in 2546 days
#1 posted 04-24-2013 03:47 AM
Good tip, thanks.
