Staining Atlantic Birch Plywood...
Forum topic by indplswoodworking posted 04-22-2013 09:17 PM 1340 views 0 times favorited 1 reply Add to Favorites Watch
View indplswoodworking's profile
indplswoodworking
325 posts in 2413 days
04-22-2013 09:17 PM
Does anyone have any tips or tricks for staining atlantic birch plywood and have it come out more even and not so splotchy? Minwax and Cabot are a joke. I have had good luck with Sherwin Williams wiping stain but curios if anyone has any other tips. Some of the techniques I have used in the past successfully are : wetting the wood to raise grain and using 120 grip abrasive paper to open the grain. Sanding sealer seams not to do anything.
-- https://www.facebook.com/MccloudsCreativeConcepts
1 reply so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3278 days
#1 posted 04-22-2013 09:26 PM
Seal the wood with the first coat of finish, then either apply the stain/dye or add dye to your finish in the color you need. Anything that penetrates the wood will cause the blotching, so the color has to remain atop the surface.
-- jay, www.allaboutastro.com
