PL glue
Forum topic by Bernie posted 04-22-2013 02:47 AM 1292 views 0 times favorited 6 replies Add to Favorites Watch
View Bernie's profile
Bernie
422 posts in 2799 days
04-22-2013 02:47 AM
I did a little experiment today using “LocTite” PL glue and the result took me by surprise. I’ve been boasting for a while how nothing sticks to my workbench’s new surface which is bamboo flooring. Wood glue, stains and paint are easily removed from my workbench.http://lumberjocks.com/topics/39419.
Today I glued 2 pieces of bamboo flooring (finished side to finish side) with the PL glue. I thought that they wouldn’t stick together, but I was wrong. I tried prying them apart and hitting one piece with a hammer… nothing will separate the pieces. I’m impressed with that PL glue.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View Dusty56's profile
Dusty56
11819 posts in 3651 days
#1 posted 04-22-2013 03:00 AM
How about a link to whatever product you’re referring to ? The only “PL” products I could find online were their Construction Adhesives. Thanks : )
Bernie
#2 posted 04-23-2013 02:06 PM
The LocTite pl (pro line) is the registered name and I hope this link works
LocTite
View Lee Barker's profile
Lee Barker
2170 posts in 2813 days
#3 posted 04-23-2013 02:08 PM
It’s impressive that it bonds materials like that as well as foam board products. Great information; thank you.
Kindly,
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3121 days
#4 posted 04-23-2013 02:51 PM
Yep, that’s a construction adhesive…Liquid Nails will do the same thing. Be careful getting it on you…it sticks VERY well to skin. Ask me how I know.
-- jay, www.allaboutastro.com
Dusty56
#5 posted 04-23-2013 10:24 PM
LOCTITE® PL PREMIUM® POLYURETHANE CONSTRUCTION ADHESIVE
“Recommended For
Bonding most common construction materials such as wood, treated wood, hardwood flooring, concrete, stone, marble, slate, masonry, brick, foam insulation of all sorts, carpets, metal, lead, cement-based products, ceramic, fiberglass, drywall and mirrors
Not Recommended For
Water submersion applications
Polystyrene, polyethylene or polypropylene
Plastic Tub Surrounds
Certain materials such as rubbers and plastics may have bonding difficulties; test before use”
Thank you.
View redSLED's profile
redSLED
790 posts in 1855 days
#6 posted 04-23-2013 10:43 PM
I use PL often whenever I have to glue 2 pieces of wood together where the 2 pieces don’t or can’t be fitted tight enough together with clamps and wood glue. Bonding results have always been very good.
Just be careful to not put too much (squeeze out) if you’re finishing the area later – any visible dried PL can’t be stain-matched later.
