Pipe Clamps
Forum topic by ChuckV posted 55 days ago 153 views 0 times favorited 4 replies Add to Favorites
View ChuckV's profile
ChuckV
21 posts in 64 days
55 days ago
Topic tags/keywords: pipe clamps
I am fairly new at LJs and to woodworking as well. I have looked around at the existing forums here and found one on clamps in general, but it looks like it has been inactive for a while. So, I am starting my first new forum topic.
I am preparing for my next woodworking project. I plan to build a Shaker bed. This will be the first project for which I need to be able to clamp something larger than my bar clamps can handle. I would like to see opinions on pipe clamps. At Rockler, I see the Sure-Foot Plus pipe clamps and the traditional orange Pony pipe clamps.
Would anyone care to share any opinions on these clamps? Are there any others that I should consider? The Pony clamps are available in both 1/2” and 3/4”. Is there any reason to not get all 3/4” clamps other than the slightly lower price of the 1/2” clamps and pipes?
Thank you.
-- Chuck - Wood Chiseler's Rule #1: Mom was right - "Don't pick at it!"
View lew's profile
lew
1750 posts in 292 days
55 days ago
The 3/4” pipe is more rigid and will not flex as much. Pipe clamps are extendable also. If you have the pipes threaded on each end, you can use couplers (available at the Borg) to add lengths of pipes together.
2081 posts in 558 days
55 days ago
If your pipe are not powder coated, place foil or painters tape on the exposed surfaces to prevent chemical reactions with the glue and the iron in the pipes.
View DaveH's profile
DaveH
274 posts in 315 days
55 days ago
I use H5956 Grizzly Pipe Clamps and have had no problems.
-- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger”
View Betsy's profile
Betsy
1883 posts in 432 days
55 days ago
I like my 3/4” pipe clamps. I have some 1/2 for smaller projects, but for the most part I use my 3/4 clamps. Like Lew I keep couplers around so if I need to “extend” a clamp it’s easy and fast. If you have some old PVC pipe lying around – you can slip a few pieces of that onto the pipe and that provides enough clearance between the pipe and the wood to keep the chemical reactions Bob was talking about. I used a lot of tape before – but the PVC is cheaper, faster, easier and cleaner.
-- Betsy - GO BUCKS!
Bookmark And Share This Page
