Red Oak gavel tear out question
« back to Woodturning forum
Forum topic by Pimzedd posted 04-20-2013 11:53 PM 1225 views 0 times favorited 3 replies Add to Favorites Watch
View Pimzedd's profile
Pimzedd
602 posts in 4139 days
04-20-2013 11:53 PM
Topic tags/keywords: turning oak
I turned some gavels recently. I had a nice piece of 8/4 red oak. The only problem was tear out on the striking surface.
Gavels were turned between centers. I used a very sharp skew but typical skew cuts were too difficult for me. I used it as a scraper with some success as long as I took very small cuts.
Tear out was very bad on some pieces. Any suggestions on how to improve the surface?
-- Bill - Mesquite, TX --- "Everything with a power cord eventually winds up in the trash.” John Sarge , timber framer and blacksmith instructor at Tillers International school
3 replies so far
View telecasterjohn's profile
telecasterjohn
1 post in 1859 days
#1 posted 04-21-2013 01:09 AM
Any time you scrape stock on a lathe you run the risk of tearout.
A shearing cut is the easiest way to get a clean surface.
Could you try to make shear cuts across the face with a gouge and then nip the last bit with a good parting tool if still in spindle form?
View lew's profile
lew
12056 posts in 3752 days
#2 posted 04-21-2013 02:12 AM
Oak can be tough to turn, sometimes.
Here are some suggestions and comments-
http://www.woodturningonline.com/forum/viewtopic.php?t=520
View Wildwood's profile
Wildwood
2305 posts in 2131 days
#3 posted 04-21-2013 11:00 AM
Why not use a spindle gouges on you mallets? I have turned several with just ¾ “ roughing & ½ “ spindle gouge.
https://www.youtube.com/watch?v=ZS5XoD8D0VI
Only time have trouble using a skew is when lose bevel support or rushing the cut with dull tool.
Nice read you may find helpful.
http://www.cnew.org/tips_techniques/spindle_turning.pdf
-- Bill
