Cross cut vs Osborn gauge
Forum topic by Mark Shultz posted 04-20-2013 01:17 PM 955 views 0 times favorited 5 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
103 posts in 2355 days
04-20-2013 01:17 PM
I have an Osborn miter gauge. its great. but i see so many folks raving about cross cut sleds. Anybody with an Osborn also have a cross cut sled? what do you use more? Same question for Incra gauge owners…
5 replies so far
View knotscott's profile
knotscott
7980 posts in 3340 days
#1 posted 04-20-2013 01:20 PM
I have both, and just find the Osborne easier to keep on or near the saw than the sled. The sled can come in handy for deeper pieces, but that really depends on the size and type of sled.
View guitchess's profile
guitchess
85 posts in 3673 days
#2 posted 04-20-2013 01:38 PM
To me, this is an apples/oranges comparison. Yes miter gauges do square cuts, but I use mine for angles and shoulders for tenons. If you spend most of the time cutting square cuts with your miter gauge, I would suggest that you try a sled.
Here are some reasons why I think you should use both:
1. With a miter gauge, I find myself constantly checking it, to make sure I haven’t knocked it out of square. This step may not be necessary with a higher quality gauge like your Osborn.
2. If you want zero clearance on a miter gauge, you have to add something. With a sled, the entire thing is zero clearance.
3. A sled gives you much more control over larger material. I find it quite comfortable to crosscut material up to 8’.
Just my $.02.
View Lenny's profile
Lenny
1593 posts in 3492 days
#3 posted 04-20-2013 02:19 PM
Mark, my comments are more in support of your question than an answer to it. I too own an Osborne miter gauge and find it to be very accurate. I wondered what all the fuss was about a sled when you have a cross cut gauge (an expensive one at that) that is working fine. So there is my support comment. Now, I have since built a sled and where I find it helpful is the situation of the larger pieces guitchess mentioned. I also learned that this is true of smaller pieces. I built slots in the base of my sled that allow you to use hold downs. I can clamp a small piece in place and cut a smaller piece from it and not have my hands/fingers anywhere near the blade. Lastly, if you decide to build a sled, be sure to add the safety features of: 1. a block or chamber at the trailing end to prevent the blade from coming through and 2. a piece of Plexiglas over the blade area from front to back.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View jap's profile
jap
1251 posts in 2019 days
#4 posted 04-20-2013 04:12 PM
I have both and my opinion is the same as knotscott’s
-- Joel
View Charlie's profile
Charlie
1100 posts in 2251 days
#5 posted 04-20-2013 04:33 PM
I have both as well. I tend to use the Osborne for “sticks” and the sled for panels. The Osborne, for me, is convenient. It hangs in an honored place on the wall right behind me when I’m at the table saw. The sled is bigger, heavier, and a little less convenient to grab, BUT…. and it’s a BIG butt….. I absolutely use both.
