router bit position on router table..
Forum topic by praspekt posted 04-19-2013 03:19 AM 993 views 0 times favorited 6 replies Add to Favorites Watch
View praspekt's profile
praspekt
18 posts in 1942 days
04-19-2013 03:19 AM
i just built a routing table out of 3/4” MDF. when i mount the router underneath with a bit placed in the Collet fully in, it doesn’t really reach the cutting depth that i need.. so i started pulling the bit out about 1/4”-3/8” and doing my routing like that. any thoughts on this? should i have used 5/8” MDF? sometime is doesn’t feel safe like the bit might break or something.. though i might just be paranoid.
any recommendations would be great!
thanks.
View surfin2's profile
surfin2
51276 posts in 3186 days
#1 posted 04-19-2013 03:27 AM
I take it U didn’t use a plate to mount the router…
-- Rick
View PaulLL's profile
PaulLL
160 posts in 2026 days
#2 posted 04-19-2013 03:27 AM
I never run my bits all the way down, I’d have to go out to the garage to look at whats in there now, but I’d think1/4 out you’d be fine with most bits. I wouldn’t pull it out more than half the length of the bit’s shaft though.
Or you could use the router to take away a little material on the underside, so you can still have the strength of the 3/4 over the rest of the table, but get the router up a little higher.
View Richard's profile
Richard
1917 posts in 2740 days
#3 posted 04-19-2013 03:32 AM
check outthe Router Forums site , they have lots of Info on instllaing routers in tables. Try useing a router plate that is only 1/4 or 3/8 inch thick. Look at this link and others on installing a router Plate.
ftp://ftp.dell.com/Manuals/all-products/esuprtlaptop/esuprtlatitudelaptop/latitude-d430user%27s%20guide_en-us.pdf
Have fun and be safe
View nwbusa's profile
nwbusa
1021 posts in 2336 days
#4 posted 04-19-2013 03:36 AM
I think you’d be okay letting the bit out that far. I usually seat the bit fully then pull it up an 1/8” or so before tightening the collet. I would think that as long as the bit was in far enough for the entire depth of the collet to be in contact with the bit shank, you’d be okay.
-- John, BC, Canada
praspekt
#5 posted 04-19-2013 03:44 AM
thank you so much for your responses! i really appreciate it.
View NiteWalker's profile
NiteWalker
2737 posts in 2627 days
#6 posted 04-19-2013 05:35 AM
In a pinch I pull the router bit up so it’s even with the inside of the collet. This way the collet still gets full grip on the bit and you get a bit extra length. I mainly do it with spirals.
