Finally got me a little band saw... What are your favorite jigs or recommended jigs?
Forum topic by AngieO posted 04-19-2013 12:12 AM 2429 views 1 time favorited 18 replies Add to Favorites Watch
View AngieO's profile
AngieO
1267 posts in 2024 days
04-19-2013 12:12 AM
Topic tags/keywords: jig bandsaw band saw
Well… Been playing in the shop. Moving things around. Making a little sawdust. Been an awesome day. AND… I finally picked up a little band saw. It’s nothing special. Just something to start with. It’s a Dewalt table top. I think it’s 7 1/2”. So I’ve been making adjustments. Getting it set up. Seeing what it can do. I figured that the first thing I’ll probably do is make some jigs for it. So… this is the best source for… well… anything woodworking so I came here first. Would love to hear what jigs you might suggest.
First question is probably going to be… what are you going to make? Well… I don’t know. My son is in a Pinewood Derby so the first thing it got used for was to shape the car. But I have a stack of wood that needs to be used up so I’m open to ideas.
Oh… I did make this as well… LOl. Just found a piece of scrap and cut ‘er down.
It made me want to go back and try making a cross cut sled for my table saw. Making this rail for the miter slot was a lot easier this time around.
18 replies so far
View GT350's profile
GT350
361 posts in 1858 days
#1 posted 04-19-2013 12:17 AM
I don’t see a fence so if you don’t have one, that would be the first thing I would make.
Mike
View boxcarmarty's profile
boxcarmarty
15337 posts in 2237 days
#2 posted 04-19-2013 12:19 AM
Angie, You’re gonna need a fence…..
-- My mind is like lighting, one brilliant flash, then its gone.....
View JoeinGa's profile
JoeinGa
7733 posts in 1884 days
#3 posted 04-19-2013 12:28 AM
Yep, I agree… make one o’ these
Oh wait. OOPS! Wrong kinda fence! :-)
View Alongiron's profile
Alongiron
644 posts in 2570 days
#4 posted 04-19-2013 12:28 AM
Angie
The 2 jigs that I use the most with my band saw is a circle cutting jig and a re-saw jig. There are many plans online for both of them. Some easy to build others not so easy to build. My Circle cutting jig allows me to cut circles from 8” diameter all the way up to 36” diameter and cuts perfect circles. FYI The first time you cut one you will think that is the coolest thing ever!! Building a fence/re-saw jig will allow you to make many cuts more safely on the band saw then doing it on the table saw. So look online or maybe try the shop-notes portion of the woodsmithshop website. Looks like a nice band saw. One bit of advice…make sure that you use some good blades on it..it will make all the difference in the world. My favorite blades are the “wood slicer” blades from Highland woodworking
Have fun!!
Steve
-- Measure twice and cut once.....sneak up on it! Steve Lien
View Chris McDowell's profile
Chris McDowell
643 posts in 2029 days
#5 posted 04-19-2013 12:29 AM
Sweet. Looks like you got a good deal. A band saw is definitely the next “big” tool I need.
-- Chris, http://www.youtube.com/CMRwoodworks , FACEBOOK: http://www.facebook.com/cmrwoodworks1 , Proverbs 16:9
AngieO
#6 posted 04-19-2013 12:35 AM
joein10asee…. LOL!!!
iamcliff… I’ve wanted one for a while. This is my starter one. I’m sure I’ll want something bigger later on. But I’m excited to have this.
alongiron…. if only I had some Cherry to resaw…lol
Looks like a fence first and then maybe a circle jig. :)
Being able to resaw is probably what i wanted it most for.
Alongiron
#7 posted 04-19-2013 12:45 AM
Angie
I could meet you at the Cracker Barrel in Seymour one day and bring you some Cherry if you like? I think its about half way for both of us!
Steve
View BertFlores58's profile
BertFlores58
1685 posts in 2799 days
#8 posted 04-19-2013 12:47 AM
Angie,
I can see that you have already the slide piece. Get a piece of flat board and attach that piece. Cut it by sliding it to the band saw and there you have a cutting slide that you can use for cutting miters for frame or slice some pieces of wood by just adding some guide pieces, stops and many others on the flat board.
Hope that would help.
-- Bert
13594 posts in 3218 days
#9 posted 04-19-2013 12:54 AM
here is a table and miter jig fence system
(i have seen a few of these but can’t remember
who did them sorry)
you can make easy
notice the table has a runner in the slot
to keep it from moving round
and the miter gauge has a fence on it
it runs in a dado across the new table
and can be moved back and forth for rip widths
and turned slightly for blade drift
i saw another with a dado parallel with the blade
and you use it regular for cross cutting
with both dado’s you get the best of each
the table can be removed if you want to tilt the metal table
(or just cut a bigger hole by the blade
so it doesn’t pinch the blade when it tilts)
but it makes it hard to keep small pieces from dropping in there
and jamming the blade
View Loren's profile
9776 posts in 3525 days
#10 posted 04-19-2013 12:55 AM
I recommend you read this book:
http://www.amazon.com/Band-Saw-Handbook-Mark-Duginske/dp/B005B1EC6Q/ref=sr_1_3?s=books&ie=UTF8&qid=1366332739&sr=1-3
It’s the one I read early in my woodworking. I checked it out
from the library and read it cover to cover. It shows how
to make a micro-adjustable fence, how to cut dovetails
and tenons. There are newer, stripped-down versions
of the same book flogging newer band saw designs and
accessories, but I haven’t read those so I can’t say whether
the same excellent jigs and tips are in those.
In any case, your local library may have a book about band saws
and they are probably all pretty good. Like hand planes,
band saws are “high spirited” tools and take some finesse.
BertFlores58
#11 posted 04-19-2013 12:59 AM
Angie,
Here is for you….Cutting sled
You may like to start the way I am doing the parquetry.
Enjoy it.
-- Bert
View kdc68's profile
kdc68
2637 posts in 2153 days
#12 posted 04-19-2013 01:03 AM
AngieO....How about a circle cutting jig ??
http://www.woodsmithshop.com/download/609/circle-cutting-jig.pdf
-- Measure "at least" twice and cut once
View Grumpymike's profile
Grumpymike
2197 posts in 2192 days
#13 posted 04-19-2013 01:06 AM
Hi Angie,
Nice Delta bandsaw … 71/2 inch??? I think it’s a 12 inch. measure from the blade to the back of the throat … (the post that goes up to the top wheel) that throat width (blade to post) is the size of the saw.
Yes, build a fence first, mine is a 3 1/2” X 5” angle with support braced to keep it at 90 degrees, I use the short side for general use and the long side for resawing, just clamp it to the table and fine adjust with a tap of the mallet. Make it a bit longer than your table. I used plywood for stability.
Blade tention is important, I raise my guides to 6” above the table and look for 1/4” deflection to the blade. there is usually a guage some where on the saw, but not all blades have exactly the same circumfrence, so the guage reading will very.
Now for the blades … Alot of folks will tell you that this blade is better than that blade … And they may be right, for the type of work that they do … For us beginners with limited budgets, We will use a mid priced blade and have about three sizes … I use a 3/16”, a 1/4”, and a 3/4” inch blades for the verious work that I do. The 1/4” is the most used.
When you do finally buy a new blade, you will have to round the back of the blade with a stone so that you can make tighter arced cuts.
Now with all that in mind take a piece of wood and make some cuts, to see what it will do. and have fun safely, keep your fingers away from the path of the blade.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
AngieO
#14 posted 04-19-2013 01:39 AM
Alongiron…. Yep. Seymour is close enough. Would love to meet you.
Bert… I’ve watched several videos by that guy but its been a while. I watched one tonight. Thanks for the link to that one. He is the one that made me really want a bandsaw in the first place.
Loren… I will check out that book.
Grumpymike… Lot of good info there.
Patron… Thanks for the pic
View gfadvm's profile
gfadvm
14940 posts in 2567 days
#15 posted 04-19-2013 01:50 AM
That book that Loren recommended answered all my bandsaw questions when I bought my first bandsaw. A good investment.
