aniline dye wood colouring
Forum topic by mikpac posted 04-18-2013 07:36 PM 1733 views 0 times favorited 6 replies Add to Favorites Watch
View mikpac's profile
mikpac
6 posts in 2110 days
04-18-2013 07:36 PM
Topic tags/keywords: question
I am trying to colour a violin with aniline dye,and finish it off with a varnish if possible.Has anyone been successful with a similar project? Any help would be appreciated. I posted this not long ago,but to the wrong posting,as I was reminded.
-- mikpac
View Alongiron's profile
Alongiron
650 posts in 2931 days
#1 posted 04-18-2013 07:47 PM
http://www.woodmagazine.com/materials-guide/finishes/aniline-dyes/?page=1
Here is a good link that I had bookmarked a while back. I followed the tips in the article and the piece turned out great. It really brought out the details and grain in the wood.
-- Measure twice and cut once.....sneak up on it! Steve Lien
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2607 days
#2 posted 04-18-2013 08:01 PM
I’ve used analine dyes on a few projects with success. I used water-based dye and found it helpful make sure I gave it plenty of time to dry, and put a couple thin layers on of sealcoat on top, lightly sanded to remove raised grain, before appyling my topcoat.
View DS's profile
DS
3045 posts in 2658 days
#3 posted 04-18-2013 08:49 PM
I first posted in your blog and am re-posting in this thread:
Spirit dyes need denatured alcohol to dissolve them.
The violin in my avatar is finished with an aniline dye.
I used an egg-white sealer and oil-based clear varnish then coated with the dye.
A clean cloth, damp with alcohol, will allow you to smooth and adjust the dye density and shading until you get exactly what you want. It is a different experience from stains and other wood finishes.
A few more coats of clear varnish seals the deal.
It might be a good idea to practice on a sample board to get comfortable with the process before you attack the instrument.
Best of luck to you.
View EPJartisan's profile
EPJartisan
1122 posts in 3363 days
#4 posted 04-18-2013 10:12 PM
Check out Triferns blog
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View Willeh's profile
Willeh
228 posts in 2577 days
#5 posted 04-18-2013 10:15 PM
I agree with EPJartisan: Triferns blog really shows what you can achieve with aniline dye!
I’ve used it on a number of larger projects with great success and have been very happy with the result.
-- Will, Ontario Canada. "I can do fast, cheap and good, but you can only pick two... "
BinghamtonEd
#6 posted 04-19-2013 12:30 PM
Get some scrap and experiment. I have a feeling this is something that, after you’re done, you’ll say “Wow, that was really easy.”
