Uprights and shelves for a radius cabinet/work station
Forum topic by 1thumb posted 04-18-2013 01:55 PM 651 views 0 times favorited 4 replies Add to Favorites Watch
View 1thumb's profile
1thumb
78 posts in 2027 days
04-18-2013 01:55 PM
A 10 ft. segment cut out of a 12’ radius at 26 inches deep/wide to be used as top and bottom. Never done this before. Do the uprights/verticals “fan” out causing the shelves to be trapezoids, (sounds stupid after I wrote it), or are the verticals ripped at a slight angle to flush out w/top and base of cabinet or am I wrong on both counts?
Also, how do I make/lay out square cuts in the arc segment? With much, much smaller segments I’d place it against the fence of slide saw, mark outer and inner lines and simply spin it to where I needed to be.
Hope this question makes sense.
View ChrisK's profile
ChrisK
1865 posts in 2952 days
#1 posted 04-18-2013 04:56 PM
Having trouble visualizing what you want to accomplish. Can you post a sketch of picture of similar project?
I think the top and bottom look the above?
120” long, 26” at deepest of a 144” radius.
-- Chris K
1thumb
#2 posted 04-18-2013 05:12 PM
That’s pretty much it, but not squared off on the inside. Something like this: http://www.phoenixmillwork.net/gallery.html?gallery=Shop%20Profile
The differences to the link are that the radius is more, inside will be functionable, shelves, a sink, place for an oven, toe kick
ChrisK
#3 posted 04-18-2013 05:36 PM
The uprights can be either, depends on how you want unit to look.
The inner uprights are fanned and the outer are straight
-- Chris K
1thumb
#4 posted 04-19-2013 08:31 PM
thanks Chris
