sanding between clear coat applications
Forum topic by Pabs posted 04-18-2013 12:44 PM 2482 views 1 time favorited 12 replies Add to Favorites Watch
View Pabs's profile
230 posts in 3390 days
04-18-2013 12:44 PM
hey all
I just put my second of coat of clear coat last night on a couple of pieces I’m working on for my kitchen
question regarding sanding..
do you guys sand (lightly) between each coat? or simply on the last one?
the few times I’ve done it I sand between each coat but was wondering if I would obtain the same results or better if I waited until the last coat
if it matters I’m using this product
water based clear coat
-- Pabs
12 replies so far
View jimmyb's profile
185 posts in 1828 days
#1 posted 04-18-2013 12:47 PM
Sand between coats and then on second to last and the last I use 0000 steel wool.
-- Jim, Tinley Park, IL
View SnowyRiver's profile
51457 posts in 3416 days
#2 posted 04-18-2013 12:57 PM
I sand between coats too. Just said lightly using a fine sandpaper like 220 grit.
-- Wayne - Plymouth MN
4909 posts in 2429 days
#3 posted 04-18-2013 12:58 PM
Sanding between coats is needed with polyurethane finishes to provide a little “tooth” for the next coat, polyurethane resins inhibit adhesion. So if I use polys I sand between coats. For everything else I’ll normally put on a few coats, smooth out the dust nibs, and then apply the final coat. With waterbornes, I’ll usually sand after the first coat to smooth out the raised grain, then proceed as I do with all other non-polys.
#4 posted 04-18-2013 01:10 PM
Anytime you expose wood to something with moisture in it like the finish, it causes the wood fibers to stand up. This is the rough feel you get after putting the first few coats of finish on. The fibers stand up and then are suspended in the finish. By lightly sanding, you remove these fibers and eventually build up the finish so it is above the fibers and it creates a smooth finish.
View Clint Searl's profile
Clint Searl
1533 posts in 2297 days
#5 posted 04-18-2013 01:47 PM
Sand the first coat to knock down any fuzz. Don’t sand after that.
View Earlextech's profile
1160 posts in 2626 days
#6 posted 04-18-2013 01:51 PM
NO STEEL WOOL on waterborne finishes! Sandpaper or Scotchbright pads. Wet the project with water before you spray your first coat, this will raise the grain, sand it out then start spraying. Sand between each coat, increasing grit as you go.
View Cosmicsniper's profile
2202 posts in 3094 days
#7 posted 04-18-2013 01:58 PM
No reason to sand between coats with water-borne…it does not require a mechanical bond. It generally dries fast enough where dust nibs aren’t a problem. However, I always smooth out with a 3M pad, just in case.
Oil-based poly needs the mechanical bond.
And yes, sand the first coat of water-borne, like you would any first coat of any finish…that’s where the smoothness comes from.
-- jay,
View Pabs's profile
#8 posted 04-18-2013 02:17 PM
thanks everyone! on my way home soon in a few minutes for coat #3!
-- Pabs
Clint Searl
#9 posted 04-18-2013 09:20 PM
Contrary to some opinions (speculative perhaps), it’s been my experience (real life) that latex/acrylic wall paint is the performance equivalent of any other cabinet finish in actual use.
View teejk's profile
1215 posts in 2621 days
#10 posted 04-18-2013 10:41 PM
Clint…I used the ACE brand cabinet paint on my kitchen and I think there is a noticable difference. It forms a much tougher “rubber” coating than any paint I use on walls. Of course that means it is a real PITA to finish. It has a long “cure time” and heat from sanding will make you swear until you realize that everything will be fine once it cools down and the curing process resumes. The other issue I had was color. The full color doesn’t arrive until it fully cures (weeks). That was a problem since I used a white primer and with my old eyes it got hard to see where the paint was.
View cutworm's profile
1075 posts in 2729 days
#11 posted 04-18-2013 11:24 PM
Just refinished a chest and used 3m scotchbrite pads. The have some for between coats and for the final rub down. I liked them. On the final I used the pads with paste wax. Turned out nice.
-- Steve - "Never Give Up"
View Grandpa's profile
3259 posts in 2611 days
#12 posted 04-19-2013 01:53 AM
Sand between coats of oil based poly. I never use steel wool until the last coat is on. I always end up with bits of steel wool in my finish no matter how hard I try to get it off my project. I sand and I learned the hard way to be VERY careful to not hit the corners. If you go through the stain you are in trouble. I like steel wool (0000) on the final coat. If you want a really smooth finish you can use an eraser from a chalk board (new and clean) and use automotive polishing compound to rub out the finish. We used this in high school and took some blue ribbons home from the state contest.
