Start capacitor for TS3650 motor....
Forum topic by DrewT posted 04-17-2013 09:41 PM 1986 views 0 times favorited 7 replies Add to Favorites Watch
View DrewT's profile
DrewT
33 posts in 1815 days
04-17-2013 09:41 PM
Does anyone know the MFD number and voltage range on the start capacitor for the stock TS3650 motor…..??
Thanks in advance!
7 replies so far
TopamaxSurvivor
18193 posts in 3582 days
#1 posted 04-18-2013 05:16 AM
No, but if the voltage rating is over your motor voltage it will be fine. Call a motor shop and ask for a capacitor for a motor of your size.
View MrUnix's profile
MrUnix
6353 posts in 2105 days
#2 posted 04-18-2013 05:53 AM
You really should get the specs from the capacitor you are replacing as the motor may not be stock or something changed by a previous owner.. they are capable of the strangest things! Otherwise, it looks like what you need is a 200MFD @ 240VAC cap according to this thread over at the Ridgid forums site.
TopamaxSurvivor
#3 posted 04-18-2013 07:52 AM
I was hesitant to give a value, but since the cat is out of the bag, most small single phase starting caps will be 200 to 300 MFD. If what you find happens to be a 400 volt, don’t worry about it. That is the maximum insulation value.
View knotscott's profile
knotscott
7873 posts in 3281 days
#4 posted 04-18-2013 09:29 AM
As long as the voltage rating is sufficient, I wouldn’t worry too much about getting the exact capacitance value….many are specked at +/- 20%, so close is usually enough.
View JoeinGa's profile
JoeinGa
7733 posts in 1913 days
#5 posted 04-18-2013 01:23 PM
I believe they’re fairly cheap at Radio Shack
DrewT
#6 posted 04-18-2013 03:52 PM
Thanks guys – also found a shop in town that will test it for me for free and they have the 200 MFD 250V capacitor it uses. I got brave and opened it up last night – I don’t do electrical or motors but I’m learning.
If this fixes the motor I will mount it back on the saw and cross my fingers – expect more questions!!
DrewT
#7 posted 04-24-2013 03:58 PM
Turns out one of the bearings was bad – $120 to repair it!! Still better than replacing the motor…
