Carriage bolts for treated lumber
Forum topic by Eric posted 04-16-2013 10:45 PM 12856 views 0 times favorited 7 replies Add to Favorites Watch
View Eric's profile
221 posts in 2444 days
04-16-2013 10:45 PM
Topic tags/keywords: zinc galvanized carriage bolt treated swing set outdoor
We moved last October. (I hope to update shop photos soon.) My first outdoor project is re-constructing the kids’ swing set we moved in large pieces. The carriage bolts that came with the original kit were badly deteriorated.
As I re-build, what is the most appropriate metal-type for AC2 pressure treated lumber. I don’t want the expense of stainless so do you prefer zinc or galvanized?
-- Eric
7 replies so far
View crank49's profile
4030 posts in 2904 days
#1 posted 04-16-2013 11:29 PM
I just checked the engineer’s bible (McMaster Carr) and compared 4 popular materials, bronze, stainless steel, hot dipped galvanized, and zinc plated.
All bolts I checked were 5/16” x 2” long.
Bronze = $2.00 each
Stainless = $1.50 each
Hot dip galv. = $0.20 each
Zinc plated = $0.10 each
Given those numbers I would say hot dip galvanized would be the best value by far.
HD galv should last about 7 times as long as zinc, and only cost twice as much.
View Eric's profile
#2 posted 04-16-2013 11:48 PM
That’s kind of where I’m leaning…. galvanized. any other opinions?
-- Eric
View kdc68's profile
2644 posts in 2210 days
#3 posted 04-16-2013 11:50 PM
+1 for galvanized
-- Measure "at least" twice and cut once
View 1thumb's profile
78 posts in 2089 days
#4 posted 04-16-2013 11:55 PM
I used to design and build wooden playsets. Hot dipped galvies
View ajosephg's profile
1880 posts in 3494 days
#5 posted 04-17-2013 12:08 AM
Might want to read this. The bottom line seems to be that galvanized will eventually fail, leaving two alternatives. Stainless or Polymer coated.
-- Joe
View Eric's profile
#6 posted 04-17-2013 12:39 AM
Eventually… anything and everything will fail. Haha.
Speaking of coated fasteners- I plan to used coated deck screws. The galvanized screws supplied with the kit (about 7 years) ago were practically nails- lacking nearly all their threads. The coated deck screws ought to address this. Thanks Joe!
For the structure 4×4s, etc.. I think I will use galvanized carriage bolts. By the time the 5/16 thick carriage bolts fail, kids will be done with the swingset. The 7-yr old carriage bolts were still sound… just rusted nuts so tight my impact wrench wouldn’t break them free. A few of the old posts are going to the burn pile because of this.
-- Eric
View juniorjock's profile
1930 posts in 3698 days
#7 posted 04-17-2013 12:43 AM
Any bolt with a head on it (un-like carriage bolts) would be okay. At least you’d have something to get a wrench on when you need to change it out. Like they said, nothing lasts forever.
