Breadboard ends, few questions.
« back to Joinery forum
Forum topic by lateralus819 posted 04-16-2013 10:04 PM 2167 views 1 time favorited 13 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2065 days
04-16-2013 10:04 PM
Been reading a lot in prep for my table, I see people do BB ends different everytime. I see one long tenon, multip shorter ones. Which is better?
Would a drawbore dowel be necessary for pinning?
Also, how tight should the M/T be?
Finally, how much roughly should i account for movement on my mortise?
I’m using 1-7/8” thick sapele the table will be roughly 46” wide by 62” long.
13 replies so far
View Willeh's profile
Willeh
228 posts in 2515 days
#1 posted 04-16-2013 10:59 PM
I did a trunk with bedboard ends about a year ago and ended up just doing biscuits.. has held together perfectly so far anyways…
Click for details
-- Will, Ontario Canada. "I can do fast, cheap and good, but you can only pick two... "
View BigMig's profile
BigMig
469 posts in 2789 days
#2 posted 04-16-2013 11:14 PM
I met Mario Rodriguez at an event where he was showing a blanket chest he had made. It had breadboard ends on its top and he pinned the tenons in oversized holes in the tenosn to allow the differential movement, but still kept the breadboard attached. Also, I think he only used glue in the middle of the breadboard to allow for movement along the rest of its length.
-- Mike from Lansdowne, PA
View TarHeelz's profile
TarHeelz
62 posts in 2257 days
#3 posted 04-16-2013 11:26 PM
This webpage goes through the method I followed for a dining room table. The page has been recommended a number of times. (I had to read it through carefully a few times to feel good about it.)
http://www.beautifulwood.net/html/breadboard_ends.html
If the design will allow it, there’s a lot to be said for cutting the ends a little wider than the table planks.
-- Tar Heelz, Durham, NC USA
View DMC1903's profile
DMC1903
285 posts in 2503 days
#4 posted 04-16-2013 11:27 PM
I use Norm’s method for building Bread board ends, never had an issue wth them.
Here is a link to his video on creating them
http://www.youtube.com/watch?v=wFCU7Buftac
Enjoy
lateralus819
#5 posted 04-17-2013 12:17 AM
I planned on making the BBs extend a tad passed, i think it will look good.
View MNgary's profile
MNgary
303 posts in 2593 days
#6 posted 04-17-2013 12:22 AM
Expect change in width to be 3/10 inch for each 15% change in relative humidity and 1/4 inch change in length for a 46 inch wide by 62 inch long tabletop of sabele.
The breadboard end will decrease/increase 1/5 inch in length with a 15% change in RH.
Note the change in dimension isn’t immediate when the relative humidity chages. The above is after the RH has been changed long enough for the wood’s moisture content to stabilize at the new RH.
-- I dream of a world where a duck can cross the road and no one asks why.
View HerbC's profile
HerbC
1790 posts in 3035 days
#7 posted 04-17-2013 12:47 AM
MNgary,
I think you’ve misinterpreted the wood movement factors. Most authorities say that longitudinal (length) movement is typically less than 0.1%...
The change in length of the breadboard is not the significant factor (nor is the change in length of the main panel.
The significant factor is the change in width (cross-grain) of the main panel. As it changes relative to the length of the breadboard ends the design must provide for movement. Typically the breadboards will be either pinned or glued in either the center (allowing for movement of both the front and back edge or on the front, allowing movement to the back.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
MNgary
#8 posted 04-17-2013 01:10 AM
My dimension changes may be wrong, HerbC. I didn’t have the change coefficient for sabele in my dBase so used the wood movement calculator on woodworkerssource.com
I agree the change in length seems high.
Edit: my error was I used radial result for length calculation – dumb mistake!
lateralus819
#9 posted 04-17-2013 01:31 AM
So leaving 1/8” gap on each end in the mortise should suffice?
MNgary
#10 posted 04-17-2013 02:20 PM
If it were my project, I’d determine length of the breadboard and its mortise based upon moisture content of the wood at time of assembly (relative humidity wood is stabilized at). I.e., if the tabletop is stabilized at a very high level of humidity vs. quite low RH or somewhere in between.
Willeh
#11 posted 04-18-2013 10:31 PM
TarHeelz, thanks for posting that link! That was a great article about how to do breadboards properly. I was looking at doing a harvest table this year and now i think i know how i will go about it!
lateralus819
#12 posted 04-24-2013 01:00 AM
One other thing i want to ask. The table with be roughly 48” long WITHOUT the breadboard ends, the stock i have for the Bread boards is 8/4 maple. 7” wide. Would that be too wide for a bread board? Or should i cut that in half?
View mbs's profile
mbs
1657 posts in 3116 days
#13 posted 04-24-2013 03:55 AM
I would cut it in half to make it look more appropriate for a bread board end.
-- Sorry the reply is so long. I didn't have time to write a short reply.
